Eaton 4.10 Gears
The rear will have to be setup with the correct backlash between the ring and pinion gears. Unless you know how to setup a rear, it will sing like a Christmas Choir and will not last long.
If it is a 4x4 don't you also have to change out the fronts as well, or do something to the transfere case?
Don't have that problem, my truck is a 2wd :(
Also, I'm a pretty technical guy, and as long as I find instructions on how to correctly set up the rear end I'm confident I can do it right. I just wasn't sure if the parts would physically fit together with the stuff I already have, or if there are other things I need in addition.
Make sure the diff carrier can be used w/ 4.10 gears. Taller (small numerical ratio) gears use a different carrier than lower gears (larger numerical ratio). I don't know the exact ratio breaking point of this change.
