Accessory fuse block
Search not coming up with much. Who has added one for additional lighting and where did you install pix would be awesome . Undecided if I want it constant hot or ignition control. If you did ignition control where did you connect. Any opinions appreciated.2017 Silverado btw
Thanks in advance
