2015 high beams uneven
Hi guys
I have a 2015 Silverado with projectors and the separate reflector high beams.  I just put in some led bulbs in the high beams to compliment my hid lows.  I noticed that when shining the highs against a wall, the right high beam shines lower than the left.  I experimented with adjusting the headlights and found that the screw does adjust both low and high beams. The problem is that if I adjust so that you high beams are even, then the right side low beam is too high.  I figured it's more important to have properly aimed low beams, especially running hids.
Has anyone else run into this or have any suggestions?  Perhaps it has to do with the fact I'm using LEDs as opposed to halogen bulbs which the housing was designed for.  Any suggestions?  Thanks!
    • Yes, and also pulling heavy trailers or a large camper up steep grades as well as descending grades such as the more rustic off road camping locations and using engine braking with that low gearing as well as soft ground can just suck the power . I realize pickups these days tend to have an over all lower first gear ratio compared to automatic transmission pickups from years back so that has helped a lot in its ability in high range but there comes a point if in four wheel drive the torque runs out at the wheels, certainly with a gas engine. They don't put two speed transfer cases on pickups for a cool factor, they have a function if one needs that massive torque to the wheels that high range can't deliver.
