Aux switches
Looking for auxiliary switch options for my 2016 2500HD. Really don’t want to cut a bunch of holes and want to
them to easy to reach.
Try the "Search" field in the upper right corner.  There are quite a few threads on here with pictures and part numbers for the various OEM switch panels.
I have a 2015 silverado 1500 LT.. I just swapped out the factory switch bank under the climate controls with a new switch bank that now has 4 Aux switches. The original bank I had, had only 2 switches, traction control and bed/cargo lights. Now that it's installed, the Aux switches light up when depressed. I found the junction box under the steering column, I am getting constant power at 2 locations and ignition power at 2 locations. I read the upfitter page and it says I need to relocate fuses under the hood. My problem is that under the hood in the designated area I don't have any fuses there. Do I need to add fuse? I tested each location in the fuse block under the steering column but none of them come on or off when I depress Aux switches 1-4. Any help would be much appreciated! !
    rayredbone
    rayredbone
  • Who's Online   2 Members, 0 Anonymous, 347 Guests (See full list)
    • Thank You.   So far my new ride is making me look like a genius for going with the 3.0L, as my first fuel refill occurred over three weeks from when I took delivery.  This engine combination is very amazing.  So far no issues and had not done a regen yet.
    • I am curious as to how much fluid you put back in the transmission ( assuming you had replaced the filter to compare to my findings ) and then went through the process of warming up the trans before pulling the check plug to drain out the excess and if you measured how much came back out.    I just found it surprising that some claimed a certain amount less fluid being put in and then draining some back out. The attitude of the truck as per if the surface is level and how the trucks stance is would make quite a difference since the check plug is right at the front of the transmission.
