1993 K1500 Suburban
I have a '93 K1500 Suburban, Silverado trim, 7.4L 454, 4L80E trans, 3.73 gears (10 bolt, 8.5" rear), 6 lug hubs. I bough it for a tow rig and it does well with my toy hauler but I am lacking power and dont want to crawl up hills at 25mph. As far as I can tell I'm sitting around 7500-8000lbs, stopping it does well, I'm more concerned with acceleration from a stop, and uphill grades. My question is, how would I go about transforming my 1500 into a tow rig?
I would sell both rigs and buy a 2500.
Gas or diesel depends on how often you tow IMO.
Only have the one rig, was sold on the engine and trans. For the price I paid for the truck I'd rather swap the running gear and make it a solid camping/tow rig.
So this 93 7.4 is a daily driver?
Someone may reply that knows more than I do.
I think the weak link is the motor.
Is it TBI.
The trans being a 4 speed isn't ideal.
The cost of transforming it maybe expensive.
Not a daily, bought specifically for camping. It is the tbi 454, but plan on worrying about the engine later. Not too worried about fuel mileage either. Ive been told by a few people to go up to 4.11s in the differentials.
411's will help.
How much better may not be a lot.
My 93 Silvy with the 5.7 tbi had 200 hp.
My 12 5.3 has over 300 hp.
4.10s will make an appreciable difference, though ultimately you're limited by the powertrain anyway. Also, it looks like a 93 Suburban towing capacity is only 6500lbs anyway, which puts you way over your safe, legal limit. Only the 2500 Burb shows a 10k towing capacity, albeit with 4.10s. Make sure you're within your limits to begin with, otherwise you may have to upgrade rigs anyway.
I happen to have a 92 truck that’s like new. They’re good trucks if taken care of. I kept it instead of my 14 for a non daily. That 454 didn’t have a lot of HP but tons of torque. It comes down to how much you want to spend. If I was just going to do gear 456 would be my choice. That would lower the stress on the drive line but raise cruising RPMs. If that’s a problem gear vendors takes care of that. If memory serves a few people I knew back with the ss 454 woke up the engine up with heads. Depending on your skill set a swap to LS driveline from a salvage yard with the goodies from the donor vehicle could be the way to go.
I plan on cam and heads later, what vehicles had the LS setup?
I had a 65 GMC step side with the engine, transmission, computer out of a 92 suburban. And an aftermarket AC that wasn’t under dash. If so inclined you could do an LS swap into your rig. My truck is a stroker with a Whipple, headers,MSD and built 700R4, 373.
Just learned that a guy from work has a destroyed '99 K2500 with a diesel setup. Going to talk with him and see what I can get from it. I dont necessarily want to go diesel, but there is that option.
I think that’s a 6.5, I’m a little rusty on my years. If it is you don’t want to do it. They were ok empty, pulling not so much.
I think he said its the 6.0. I dont know much about the diesels.
    CaptainDad
    CaptainDad
  • Who's Online   3 Members, 0 Anonymous, 611 Guests (See full list)
