Helper Bag Kit Questions
I have a 2015 Sierra Denali that is lowered 2" in the rear. Looking for a helper bag setup for it. Air Lift says they don't make a kit for only being 2" lower. Firestone says not to be used with magnaride. McGaughys says they don't have one either. Anyone have any input? Thanks in advance.
Depends on how it was lowered?
Was the axles flipped?
The over axle then cut out the factory axle stop bracket and mount the air bag bracket straight to the frame. And that is a big bag kit.
Then there are kits available that mount over the axle and leafs the. Have a upper bracket that bolts to the factory bump stop mount.
I found all those kits and they all say cannot be used with MagnaRide. Air Lift has two kits that will work with MagnaRide, one for stock height and one for a 4"-6" drop. I will probably try the slam air kit and make it work.
    ar0517
    ar0517
  • Who's Online   5 Members, 0 Anonymous, 587 Guests (See full list)
