Don't know on 3500 but when I was having problems with mine they said its all located under rear bed spare tire.
Edited by elcamino
Did you see this in the Q & A section?
GM part number 23114650 replaces 23104453. However, both part numbers have been updated and replaced. The current part number that a GM dealer would recommend is 23337305.
4 minutes ago, NYRESCUE said:
I checked but didn't see anything when I dropped the tire.
You sure the truck has this feature?  Cannot be added.
Should be a bracket, left rear of the frame.  If you drop the spare, assuming its a pickup, you should see a module on a bracket.  The trailer brake control module is on top of the bracket.
OK, I found it..yep its on top of another module when you drop the tire. Thanks!  I replaced it with the part I listed above, not knowing there was a new version. Is this still ok or will I still get the disconnected message with this version?
Edited by NYRESCUE
  • 5 years later...
Hey all. I have a 2015 3500HD with the trailer brake message. I am told by the dealer that there are two modules that look exactly alike, but only one is for the trailer brake controller. I found one of them, thinking it was the correct one, and replaced the module, but this did not fix the issue. This truck has a service body, and a second gas tank where the spare tire would typically go. Dealer states that the second module should be above the spare tire location where the additional fuel tank is now located. I looked above the tank as best I could, but could not locate the other module. Can anyone tell me where it could be located? The one I replaced was easy to find. It was on the front of the rear fuel tank, next to the fuel pump control module. As for module I'm looking for, can anyone give me some insight?
Sounds like you have a 3500HD chassis cab so the dealer would be incorrect in their explanation.  Pickup trucks or box delete pickups which would use the regular boxed frame, the modules would be above the spare on a bracket.
Chassis cab so the big open C channel rear frame rail trucks, its different.  See below.
Trailer brake is operated via the chassis control module (the big guy), the trailer brake power control module (the little guy), and then the trailer brake control switch in the dash.  The switch in the dash is a common failure point too, so don't rule that out.  The system does set codes which have diagnostic trees to follow as well.
Edited by newdude
    • I work at a Chevrolet dealership & hear it all believe me.  Just reads like there's going to be a fist fight over filters.  Can't get enough, continue!!
    • I just can't think of the exact term GM uses for that higher gvw package without looking at the website but basically sort of a trailering package and I imagine it may also have been created to skirt around the licensing fee differences between a3/4 and 1 ton that apply in some states although ironically I believe in some states its the reverse that a 1 ton is the cheaper truck to license over a 3/4 ton. It makes no difference here in Alberta but oddly enough a 1 ton through my insurance company is a bit cheaper to insure over a 3/4 ton as its based on the insurance statistics they generate.    For sure when ever you do have the chance to weigh your truck and to be fair, try to have the fuel tank full or nearly so rather than give yourself a false sense of the truck being lighter by having an almost empty tank.    In my other comment I was mentioning stock sized tires and partly in case someone was reading this and thinking they could lower their pressure down to what your aftermarket tires are able to do with your empty truck as that is a vastly different picture in the leeway you have to play with for running minimum pressures while remaining safe. I will say also that its easy to see from reactions of truck owners that may have been more used to owning a half ton in the past or a car and be it on a forum like this or in person etc that they get so wrapped up in that placard pressure sticker that they can't get their head wrapped around the fact that an HD truck due to how much it can carry can also vary the tire pressures drastically lower than those pressures ( typically more so for the rear axle on stock sized tires ) when empty vs some car that isn't made to carry much so the tire pressures can't be lowered since it needs almost that much pressure just to carry the empty car.    If I ever do find myself in the states with this truck, I will only be too happy to switch it over to the US measuring system as then I will understand all the dash readings. The only thing that is off for me slightly with US measurements is US miles per gallon as I grew up with the Imperial gallon and to this day up here anyway speak in Imperial miles per gallon ( I don't do that on this forum though as that would confuse everyone for no good reason ).
