Vibration help
5 minutes ago, Matthewsteven1989 said:
Yeah, I've changed everything that was loose or needed to be changed except the drums, but I got new ones on the way, bendix brand and machined and balanced perfectly.  New tires, they are all within specs, 2 new u joints installed when I had the driveshaft checked(he said it was perfect) new moog upper control arms, front end alignment. Driveline angle seems to be in spec if I measured right. New engine mounts bc they were destroyed. But everything changed when I clocked the drum 1 stud.
A bad thought,should you check run-out on rear axle flange?
I've done that on the right side, haven't on the left side yet. No noticeable lateral runout on the right side. Has the typical "oval" flange tho, so it's not perfectly round...
    Patrick Fergy
    Patrick Fergy
  • Who's Online   3 Members, 0 Anonymous, 1,014 Guests (See full list)
