4l60e shift solenoid
I just recently got a 97 c1500 Sierra. When I bought it, it had a code for the shift solenoid. I went ahead and replaced both solenoids, now when it's cold it'll run in limp mode until it warms up. After it warms up, I'll pull over to a gas station and turn it off for about 5 minutes then it drives absolutely PERFECT. Until it cools back off. Any guesses on what I need to fix it???
Sent from my LG-G710 using Tapatalk
Ok, check trans fuse for battery voltage, when you were underneath,any harness look altered,not in perfect condition?
Not that I saw, it was an old man's truck, so everything is completely original and LOOKS perfect
So I checked the codes again and came up with:
P0740 TORQUE CONVERTER CLUTCH CIRCUIT/OPEN
P0785 SHIFT TIMING SOLENOID
P1860 TCC PWM SOLENOID ELECTRICAL
I couldn't find my multimeter to check the voltage, but according to my handy test light, it does have power to it. After researching constantly everything sounds like it'd be the Ignition Switch except for the gauge cluster has been working fine.
    • Yes, and also pulling heavy trailers or a large camper up steep grades as well as descending grades such as the more rustic off road camping locations and using engine braking with that low gearing as well as soft ground can just suck the power . I realize pickups these days tend to have an over all lower first gear ratio compared to automatic transmission pickups from years back so that has helped a lot in its ability in high range but there comes a point if in four wheel drive the torque runs out at the wheels, certainly with a gas engine. They don't put two speed transfer cases on pickups for a cool factor, they have a function if one needs that massive torque to the wheels that high range can't deliver.
