3 hours ago, KennyMcCormick18 said:
I have an issue with my door locks too I have figured out it is only when it's around a certain vehicle it effects two different GM vehicles at my house so far there is no tpsm issues but the car effecting it does have a tpsm issue. Not sure if this helps but could give you something else to look at.
Oh My God! They killed Kenny, you Bastards!
Someone had to be the first......
Haha I don't get that near as much as I did 20 years ago when I made the screen name.
There are still diehards out there like myself, have a stack of dvd's that I need to sit down and watch someday.
I'm having a problem with my 2015 GMC Sierra HD.  The Remote Control door lock and start no longer function.  The Tire Monitoring system no longer functions.  I've purchased a receiver from my GM dealer with the assumption that the original receiver has failed.  After reading this line of comments, I'm a bit depressed that no one has found success solving their problem.
I was happy to find this line of commentary just to find our where to locate the receiver.  I'll work on exchanging the receiver this afternoon and see if that fixes my problem.
Looks like I've joined the club. Too busy to go hunting so I'll just follow here and hope for a breakthrough.
  • 3 months later...
Same issue here.
Watching for someone to have found the location of the issue.
 I found a service bulletin of the same issue on newer models of Chevys.  In the bulletin, they describe the intermittent problem (like I have) means the trouble is closer to the "antenna amplifier module" .. but looking at the diagram on my phone doesn't make the location clear.
https://static.nhtsa.gov/odi/tsbs/2017/MC-10139215-9999.pdf
I will go poking around and report back if I find anything.
Anyone know if the module has an internal antenna or an external one and were it is? Been looking around and haven't had any luck yet
Finally got mine fixed.
My truck is a 2014 Silverado double cab with the 4.3 V6.
Neither my key fob nor my TPMS would work. I replaced the RCDLR and that didn't work. Followed some wires and didn't see anything broken, so I took it to a good mechanic. They found that there was no power going to the RCDLR, so the first thought was a broken wire somewhere in the wire harness. Normally the fractured wire would be under the door sill where people step to get in and out of trucks - that seems to be where most broken wires are found.
There was no breaks there so they traced the wires to the BCM and there was no power coming through BCM on those pins. Decided to replace the BCM before more things started to fail in it since they only ever fail in one direction. Power was now going from the BCM to the RCDLR, but still wouldn't work.
After a lot more diagnosing and time they finally found that the shark fin antenna had been leaking. That is par for the course on these vehicles, but doesn't normally cause critical issues it seems. There was never any wet spots on the headliner in the cab, so I never noticed that it even had a leak unfortunately.
They found that the leaking water was getting into the connectors and causing issues with power going to and from that particular cluster in the BCM. Those 20 or so wires had corroded badly and were causing incorrect voltages, arcing issues and other problems around the BCM. If the truck was suffering with just a lack of key fob and TPMS I would not have fixed it, because it was a stupid amount of money to spend on an 'accessory'. I would have just replaced the leaking antenna myself and sealed it better. Since I didn't want to cook my new BCM or cause any more damage down the line where the truck may just not start anymore, I asked them to go ahead and fix it.
They basically bypassed the corroded connector X225 near the BCM, replaced the antenna and sealed it better, and replaced/cut back any corroded wires so that they are clean and don't cause any more shorts or arcs.
This fixed the key fob and TPMS issues thank the Lord.
Only took about 10 months and way too much money to figure out, but I hope this saves someone money and time down the line.
    • Can it still be Assembled I?    Stribeck says that we need a certain amount of viscosity under conditions of load and velocity to prevent two surfaces of a know roughness from tearing each other asunder. And we have marketing trying to tell the masses that those two surfaced require less of that commodity due to more exact limits being placed on the same old clearances. We also know that there are limits to how hard something can before it becomes to brittle to be viable and to smooth to 'wet' the surface and that both of those conditions have been known and met since about the Second World War.    That viscosity value shook out at 10 centistokes at 212 F just under a hundred years ago.  Give this a look: [Anton Parr]     What is advertised is the Kinematic viscosity (mm2/s) or that which has been density adjusted but the value we are after is the dynamic viscosity (mPa.s) or true viscosity. You can see that this number is dependent on density thus base stock and temperature. You can also see that an SAE 30 doesn't reach that value in this example. However an SAE 30 that is at the upper end of the SAE 30 range; 12.5 cSt (mm2/s), might. 12.5 * .83 = 10.375 (mm2/s). If you could find an SAE 30 at the upper end these days.   Then there is the complication of viscosity modifiers or VII or VM, whatever you wish to call them. Polymers added to very thin base oils, perhaps 3 to 6 cP oils, that will meet the SAE *W30 spec at 'tested' shear rates and 100 C/212F  target temperature. So a polymer fortified base that is a fraction of the 10 cP requirement Stribeck insist upon.   This could be all well and good if those polymers didn't have two very problematic 'features'. They shear or loose viscosity both 1.) permanently and 2.) temporality. And they do both omitted in the advertised data with the distinct  purpose of deceiving the consumer of the actual operating state of the fluid. I've shown the example of Warren Oils COSTCO 10.91 cSt 5W30 formuation several times where the 100 C HTHS value is 6.9 cP!! That's the temporary shear down and with and SSI or shear stability index of 9.4 cSt. Note the intentional deception in using mixed units?    After a short while that 9.4 cSt oil has a viscosity corrected dynamic value of 7.8 cP. But as the SSI is still within the range of an SAE *W30 whose lower value is 9.3 cSt.    This allows them to continue to call this SAE 16 weight oil a 30 weight, the cake, and still meet the API requirements for fuel efficiency IMPROVEMENT mandated by the EPA. The eating of the cake. By the time you've worn out your motor doing the responsible thing by adhering to the warranty requirements, (the stick), you get deprived of the carrot, wear control. So sad, to bad.   So what can be done? Do I need actually say? [Anton Parr]       Even this must be monitored if the oil is on the low side and the VII an organic or you opt for a 0W40 with an even lighter base oil and more / higher MW VII. (Note the lower density of the 40 weight versus the SAE 30 mono-weight?)    There is another workaround. Temperature. An SAE *W30 run at a bulk temperature of between 180 and 195 F.    Being the belt and suspenders sort I am I do both. Run it cook and run it heavy.    In Part II I'll work the AW package.
    • So, do I go elbow-deep on this thing or list it for sale and play dumb? Seems to "runs good."   I'm about $1200 away from having: -a rebuilt injector ($300) -a new cat ($250) -a new cat back exhaust (OE style) ($300) -a new AC compressor ($200) -AC refrigerant charge ($150)   In theory, this should rectify the obvious detracting issues from its value and operability. Cold AC with a non-squeaking AC pulley both sounds and feels good. An exhaust that isn't cut/hacked in 17 different places and doesn't vibrate on a crossmember would make it sound and feel less janky. A working cat would help the stink, and will save the earth, but *if and only if* the fuel system is working properly, which would also address the intermittent "rich" CEL.   Heard a good one... CEL for "Rich condition" means you haven't spent enough money on the truck lately, and it's letting you know.   Rebuilding the injector would seem to be the most important part. Replacing the cat would be secondary. I don't think mine is plugged or overly restricted, but it might be a little restricted? I have no good way to tell other than seat of the pants feel. I hate the smell.   The current theory is I have a rich idle problem: A bad fuel pressure regulator, or a leaking injector(s) being the highest probabilities. I already replaced the FPR but that doesn't mean its replacement isn't also bad. It was a new part from Dorman, but the packaging looked like it had been sitting on a shelf for 20 years.   This is the (single) upstream O2 sensor shown at idle. I'm getting a lot of "rich" it seems. Sometimes it stays high like that and doesn't drop down. That makes me think it's processing injector leaks or a partially stuck open injector.     Other times it looks like this. Nice oscillations between rich and lean, which is what I think it should be. Under load and at speed, the oscillations are nice and tight and uniform looking, high and low.     Fuel trims suggest the PCM is compensating pretty hard at idle to pull fuel out. But it's not enough to trip a CEL. Something about slowing to a stop: brake vaccum booster, EGR, or the EVAP purge is delayed, or there's pooled fuel in the intake again that's draining into a cylinder is enough to set the CEL. Of course, in two days of driving, it hasn't set. I was hoping to actually look at the freeze-frame data when it sets. IAT is high because it's idling on an 83 degree day here.
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
