Replace a Tire
I have to get one new tire due to a large gash in the sidewall. The tires only have 15,000 miles on them. Should I get all new ones or will it be okay to have 3 tires with 15,000 more miles than the one I am replacing.
I would be replacing the stock tires that came on the truck. What tires would be good for a 2wd Silverado if I were to replace all of them?
Most of the time the stock tires are 30K lifers, so it's possible they are about half worn. You can take the truck to a tire shop to have them measure the tread depth or do it yourself. If the tires are close to half worn I would replace them with good 50-60K tires, I always had good luck with goodyear, quiet and good rain/snow traction. If they are still good, 1/4 worn, just replace the tire it's cheaper. :rolleyes:
It would be best to at least replace the tires in pairs. When you have different tread depths side to side (left front to right front) this can cause a pull to the side with the most worn out tire.
I would buy one more for sure. Put the new ones up front and the existing in the rear. :rolleyes::jester::cool::lol::lol:
Hey, assuming your *spare* is still new, why not pull that one off and replace it with one of the worn ones, buy your one new one and there ya go!, two new tires!
