How To Diagnose Misfires That Don't Throw The CEL
i have an 04 silverado ss 6.0 365,000km, do all the work on it myself, but this problem had me stumped.
I was getting a P0300 code rough idle flashing CEL i replaced the intake manifold gasket with a Fel-Pro one torqued to factory specs first 44 in lbs then 89 in lbs in the factory order. Then i was getting a p0303 code, moved that coil to cylinder 5, got a p0305, moved it to cylinder 1, got a p0301 code. Obliviously that coil was bad, Replaced coil. Seemed to fix it no codes being thrown but i can still feel misfires, took it to mechanic, they concluded :
(1-2 misfires every cycle or so, (normal running condition))
My question is, is that a normal running condition 1-2 misfires every cycle?
I wish they told me if it was in bank 1 or bank 2 or both.
Parts that are new in the yearish or less
all spark plugs
all spark plug wires
all ignition coils
all O2 sensors
MAF sensor
Vapor Canister Vent Valve / Solenoid
Fuel Tank Pressure Sensor
Vapor Canister Purge Valve / Solenoid
I wish i had the devices to look at the fuel trims graphs and 02 sensor graphs and cylinder misfires numbers. Then i could try myself.
What can i try to diagnose these misfires? is what the mechanic said normal? should i find a different mechanic to actually diagnose it?
Is it a vacuum leak? is the intake manifold gasket leaking? Any tricks to test those?
Not sure about misfires being normal, would drive me nuts if they were.  I have a Tech-2 and my truck has NEVER shown a misfire on any cylinder.  There are Bluetooth adapters that work with apps on your phone that would allow you to see misfires.  Not all, so you'll have to be thorough but I would start with Torque Pro.  Scotty Kilmer on youtube recently reviewed an app that even allows remote diagnosis, you run the app and I can see the data live or recorded on a website.  Tech-2 aren't all that expensive anymore, about $350 compared to years past.  GM has moved on to other tools.
The diagnostic tools on the Tech-2 allow you to graph sensors and run tests on the coils and injectors and other advanced, bi-directional scan tools have the same features.
I changed a negative battery cable awhile back,solved one issue,created another,g102 on left of engine,below exhaust manifold has the coil ground also,I twisted it, installing new cable,gave me a 300 code,repaired that small ground,good to go,worth a look
Do you notice it running rough?  I've seen a few vehicles have a misfire on occasion and still run good and not set a cel light.  Also, you may try to have the crankshaft position sensor relearned.  I've seen that cure a few odd misfires.
I second this. If one is getting a stored P0300 but no CEL or any observable driveability symptoms,  it seems a they are solved by a crank angle relearn. I've fixed this a few times, once on my last truck.
Ill check it out. I have also heard about blue driver bluetooth. Its about $100 does LT & ST fuel trims, and engine misfires.
For sure ill look into those ground wires. thanks.
I can notice the misfire just because its been my daily driver for 8 years, it isnt rough, pretty smooth not throwing a pending code or CEL light but i can feel it.
Now that i look on my bill from the mechanic i can see they did a CKP variation relearn. So i guess that's not it.
    appletrav
    appletrav
  • Who's Online   0 Members, 0 Anonymous, 286 Guests (See full list)
