Transmission issue
Rosie A&P
Hello all,
Im new to the forum and i need some help/advice. I have a 2014 GMC Sierra 2500Hd 6L vortec.
well last week i had some issues accelerating. It would rev really high and kind of jump on me and shift hard, so my dad recommended that i drop the pan, change the fluid and filter. I did that and it did Help. But now it downshifts slightly rough and when im slowing down the rpms will keep jumping back and forth between 1000 and 1500 rpm, until im completely stopped. Which i had never noticed it do this before the issues. Its doing well with accelerating and does fine while idling.... am i paranoid? Any suggestions?
thank you so much for the help!
If you can have access to a nice scan tool I'd try resetting the adaptive learning and see if it helps any.
I tend to drive the trucks kinda "rough" to make them do all sorts of shifting and thinking after I reset those.
On 9/25/2019 at 4:09 PM, Rosie A&P said:
Slvijoe, yes it does.
Same here, United Airlines. Maintenance Base At San Francisco. Mainly Boeing’s 777.
How about you?
    Fishboat
    Fishboat
  • Who's Online   2 Members, 0 Anonymous, 458 Guests (See full list)
    • Thank You.   So far my new ride is making me look like a genius for going with the 3.0L, as my first fuel refill occurred over three weeks from when I took delivery.  This engine combination is very amazing.  So far no issues and had not done a regen yet.
    • I am curious as to how much fluid you put back in the transmission ( assuming you had replaced the filter to compare to my findings ) and then went through the process of warming up the trans before pulling the check plug to drain out the excess and if you measured how much came back out.    I just found it surprising that some claimed a certain amount less fluid being put in and then draining some back out. The attitude of the truck as per if the surface is level and how the trucks stance is would make quite a difference since the check plug is right at the front of the transmission.
