Stabilitrak light
15KSChevy
My stabilitrak light is on after installing a zone 4.5 inch lift. It is scheduled for an alignment tomorrow and the truck is pulling pretty good toward the right and the steering wheel is pointed to the left, as I was expecting it to be off anyways from doing alot of work with the suspension and so on. Anyhow has anyone had there stabilitrak light come on and what was the reason for it? Is this something that will go away after the alignment? Also could it be something as simple as a dirty abs speed sensor that I can clean off myself? Thanks for any help.
steering wheel sensor bad. you can also check the DIC display, under attitude angle meters make sure they jive with your front wheels
