My new 2019 Silverado has a issue with the radio volume. In the past couple of days, the volume goes to full plast when I start the truck. I can’t do anything with it screen freezes the only thing I can do is to shut off the radio with the knob. I always turn the volume down when ever I exit the truck
   Help me my ears can’t take it anymore!!
There is a setting in your menu on the infotainment system.  It is on page 95 of the Infotainment System User Manual, for your reference.  It is under Settings and "Maximum Startup Volume."  I was annoyed by this as well.  I adjusted mine down to zero.
Thanks Geddylee 2112
   I found it in the infotainment system manual but my manual only has 82 pages. I did find the settings you were talking about and I turned down the start volume to 0. Lets see what happens tomorrow
I found the manual online so I was probably wrong on the page number.  Sorry about that.  I should have walked out to my truck and grabbed the manual.  I hope it worked for you this morning.
I tried starting the truck is morning and everything is fine. Through out the day everything is working great! Started it one time and the radio came on at a really low volume for a second. Then stopped after that evening works as it should.   I guess I can live with that till I get to the dealer
thanks
I HAVE A 2021 CUSTOM TRAIL BOSS AND MY RADIO VOLUME, PHONE RINGER AND HONE CALL VOLUME , TREBLE AND BASS SETTINGS ALL RESET TO ZERO IF I TURN OFF THE TRUCK FOR MORE THAN 30 MINUTES.  SO BASICALLY I HAVE TO FIX ALL THE SETTINGS EVERY TIME I GET BACK IN THE TRUCK. HAS ANYONE ELSE HAD THESE ISSUES?
Mine resets all settings after having the truck off for a half an hour. When the truck starts the radio is on full volume and all of my radio settings are back down to zero. I have no idea how to fix it. I’ve changed the maximum startup volume hundreds of times and it never saves
My max startup volume will not stay set. Radio on at nearly max volume upon starting truck. Have had to reprogram bass, treble, etc. several times as well.
  • 8 months later...
I have the same issue.  Where you able to find a solution?
I have 2019 the volume will crank all the way up on its own, if I use the wheel controls to search pre set channels it will continuously scroll through and can not stop it has any one had these issues and has anybody found a fix for it
    DM22
    DM22
  • Who's Online   2 Members, 0 Anonymous, 2,479 Guests (See full list)
    • I thought I would use your thread and add to it as I just did my first longer drive with my truck in the last couple of days. I drove from the Grande Prairie area of Alberta down to Edmonton and most of where I drove in the city was the ring road so fairly free flowing but a bit of stop and go as well in the city. Stayed the night and returned home and not too many stops along the way each way but every restart and certainly every cold start sets it back for fuel mileage. Why I say that is I see some people will cherry pick a fuel mileage leg after the vehicle had been warmed up driveline wise before hand and its a forgiving ( easy rolling drive leg for example ) and call that their fuel mileage which can give a false perception of reality. I was not heavily loaded at all but never the less the flip bak cover, rubber bed mat, various tools etc and extra jerry cans of fuel all way up to a few hundred pounds of dead weight so its not an empty truck. The cold inflation tire pressures are set more near the freezing point so once they are warmed up driving I was showing 45 front and over 40 rear and realize high inflation pressures would help a little in fuel mileage but certainly not the ride on our crap sections of highway. The weather was good so was not raining as that can really drag mileage down, in fact I had a bit of a tail wind on average driving home. Most people on here would never have driven on that freeway to visualize it but its got a fair bit of rolling type of landscape with numerous river valleys. For the most part I had it on cruise set to 62 although kicking it off if I caught it in time before it started down shifting and self braking going down the grades. Most of the more substantial grades its shifting into 7th I believe as 8th just doesn't have it. Total distance round trip was 643 miles and my overall average and I did refuel three times in all, figured out to 17.65 miles per US gallon. My best fuel mileage section refuel within all of this figured out to 18.46 and these are all hand calculated figures. I find if anything that the trucks computer can be over optimistic, sometimes its pretty close but other times its stretching it. On paper persay in theory the truck would have just about made it on fumes for that whole drive without refueling once.    Which made me think of the topic thread of the wonder if these trucks could do 20 mpg and that is a good question, certainly would have to be on an easy going flat highway, no head wind, the right temperature, not packing around a bunch of dead weight and puttering along even slower than I was I would suspect and going steady and not stopping to smell the flowers or take a piss !. It probably is possible but not without effort to attain that with the wind resistance and weight of these trucks. Of course on my drive most people are passing me if they have the power as per loaded highway tractors, never mind a lot of speedy vehicles but the speed limit is 68 and most are at or well over that.
    • Paid $2.72 for E85 today.
