Polishing Driveshaft
I was wondering how you go about polishing up the aluminum driveshaft for the Z71 trucks? I have seen some of the trucks with the driveshaft polished up and would like to know what the exact procedure is. Thanks
If it were me.. I'd put the truck up on Jack Stands and then put the truck in gear and let it idle..
then take some wet sand 400 grit and loop it over the shaft. Let the spinning to all the work.. make sure you don't have any loose clothing on.. :jester:
You'll need to do it once a year to keep the shaft looking good. It's been about 5 months since I did this and the shaft isn't as shiny anymore.
Tom
The buffer really brought it out in the end. I was using steel wool to clean it up before I buffed it.
Do NOT try to polish it in place on stands with it running and in gear as someone suggested!
True. not a good thing to do.
Tom
Thats insane man!!
:fume:
Too much work for me :D
1. Some of you guys are too hard core!! :D
2. You guys have way too much time on your hands! :D
3. I use my truck daily, so keeping the paint and interior somewhat clean consumes all my spare time.
4. I wish I HAD that much spare time. :D
5. My wife is the best driveshaft polisher I have ever known! :fume:
then take some wet sand 400 grit and loop it over the shaft. Let the spinning to all the work.. make sure you don't have any loose clothing on.. :fume:
:D No thanks, I like my arms attached to my body.
    • A complete delete is the most thorough mechanical solution, but it is also major engine work. On a quiet truck that is still under extended warranty, opening the engine purely as prevention is difficult to justify. A plug-in disabler stops commanded cylinder deactivation, but it does not remove or repair the collapsible lifters, so it should not be treated as failure insurance. I would keep the oil full, document the maintenance, and have any persistent tick, misfire, or loss of power diagnosed promptly. If the engine eventually has to come apart, that is the logical time to compare an OEM-style repair with a complete delete. The right choice depends on the truck’s symptoms, warranty status, expected ownership period, and whether the engine already needs to be opened. We explain that decision in more detail here—full disclosure, this is our own guide: https://www.bluev8.com/blogs/news/do-you-actually-need-an-afm-disabler   One exception: some 2021 L82/L84 trucks have RPO YK9, meaning cylinder deactivation was already disabled in the factory ECM; on those trucks a plug-in disabler is redundant, although the AFM/DFM hardware remains inside the engine.
    • Brought my 2015 Colorado into the dealership to check my touch screen issues, had that ghost touch thing happening. They said I needed a new touch screen and they could either order me one for $500. The lady at the service deck was nice enough to tell me I could order a touch screen online for less, she did stipulate that the touch screen had to be factory OEM, you can't pair an aftermarket screen to my radio seeing it was 2015, it had to be a GM factory OEM only. I found a few on Amazon and Ebay by the numbers on the back of the old screen, DJ080PA-01A GM# 22740886, Some said "OEM" in the description and others just said "Replacement". Would a replacement be the same as a OEM as long as it had the same numbers on the back of the screen? In some of the descriptions they also show different brand names but same numbers, is that an issue?
    • I have both but typically use the 4 legged walker (wheels on front, ski's on back).   The four wheeler is starting to be used on "longer" outdoor walks.  The 4 legged walker is particularly helpful in practicing good walking posture.  Both of my knees are at different stages of recovery and I'm trying to not develop poor habits.  I can actually manage with a cane but it's very difficult not to favor one leg over the other.  My PT recommends I continue with my 4 legged walker for a while.  Yesterday was four weeks since my last knee replacement and I'm excited about my progress to date.  It has been a hell of a rough journey so far but it is exciting to witness  systematic and continuous improvement.  I went for years watching the decline of my "mobility".  It seems that everyday now I am alerting my wife to something I can do now that I couldn't a day or two ago!  I encourage anyone facing the prospect of knee replacement to share any concerns with others who have had the surgery.  It isn't an instant fix but rather is a considerable amount of short term pain for long term gain.  Recovery time and pain levels vary for individuals post surgery but the end results are typically very positive and I've never encountered anyone regretting having had the surgery.
    • The lifter issue can be dealt with by shorter oil changes and quality oil IMO.
    • Got heavy rain, hail and light rain yesterday.
