Leveling kit and tires for stock wheels
Hello everyone my name is Bill and I am new to the forum. I’m sure there are plenty of this same post but I haven’t been able to find the exact one. I have a 2018 Silverado 2500HD that I would like to put a leveling kit and put the largest tires I can on my stock 20in wheels. Please reply with any suggestions on which kit and tires. I want to run an AT tire.
Thank you
  • 2 months later...
New to the forum also. I just put Cooper AT3 XLT on my 2015 2500 High Country. I went with 285/65 r20 on the stock wheels. This measures out to a 34.6x11.5 tire. I have not done a leveling kit or TBar crank
yet. They do fit Without rubbing on flat ground, but I would imagine they rub pretty good as soon as you get off road. I am going to crank the bars about 1.5” to get it closer to level, put new shocks and call it good. If you do any off roading I might recommend going one size smaller, I just took off a set of 33x12.5 r20 that fit with plenty of room. Those were Atturo Trail Blade XT I would stay clear of those unless you like loud tires, they howled from 15-80mph. Took them off with only 2500 miles, drove me crazy.
    I purchased a 2017 2500HD Denali that had a level kit installed. Truck looked great, after driving it for a couple weeks never liked the ride. After reading info posted here and other places online I figured out why.
   There was very little down travel left in the front suspension, the upper control arms had less then a 1/4” before bottom out, the ball joint was pushed all the way over to the outside, basically in a bind. The ride was choppy and harsh, even at slower speeds over speed bumps potholes etc.
    So you may want to rethink just leveling. Unless you do it using Upper Control Arms with the correct geometry. Differential drop, shock spacers or new longer shock. Buying these parts individually cost more then complete kit from Rough Country.
  I decided to install a 3.5” Rough Country lift. This kit includes everything needed at an affordable price and made the ride 100% better. There are other kits out there but they are all near 1k more in cost.
    After installing the kit last weekend, I took the truck to Les Schwab for an alignment. While there I asked them what size tire would fit using the stock wheels. They are telling me 295/65r20 which is a 35” no problem. I am going to give these a try next month, after I collect a few more pay checks. I will let you know how it turns out.
   Here is. Couple pics. The first pic you can see where the Stock UCA was making contact with the stop right above the brake line.  The second one shows how much better the geometry is at the ball joint.
Good luck, hope this helps.
Check out Central Coast Motorsports (ccmoffroad.com). Their leveling kit is $550 and includes UCA, keys, shock spacers, and diff drop spacers (diff drop is sold separately, but included in the $550 price). I have been running it for about three and half years...no issues. I sit just below level and it rides just a little stiffer than stock. The ride did get much better when I later added the bilstein shocks and got rid of the stock junk rancho's. Shocks are not included in the above price.
I ran 275/65R20 BFG KO2 tires, but they were a little small / narrow in my opinion - especially with the level kit. It was time for new tires and I just put on 285/65R20 Nitto Ridge Grapplers about three weeks ago. This size looks a lot better - tiny bit taller and tiny bit wider. Both sets of tires were / are on the factory wheels. No rubbing with the larger size as of now, but I haven't put them in any extreme angles yet either - but there seems to be plenty of room.
Attached pics are with the older 275 tires, CCM UCAs (before I installed the bilstein's), and my CV angles...
    RichardRS
    RichardRS
  • Who's Online   1 Member, 0 Anonymous, 792 Guests (See full list)
    • Well that book won't sell many copies. Taking ones right foot off the loud pedal never gets applause. Funny really, It isn't that people don't know what to do...they just don't want to do it. But they will complain about it. About bad craftsmanship, about the cost of fuel, about the cost of part and repairs and mainly they complain that the solution while still possible isn't one they are willing to do.    I observe this daily. 'Gas cost to much!", they wail, while they mat it passing at 80+ mpg and scoot down the road like gas cost a dime a gallon. Then complain about the few that will lift and save both fuel and iron like they are owed and own the road.    Good thing they haven't an ounce of influence on my equipment. The rest I just laugh at. Stupid is as stupid does, right Forest?
    • Today I filled up with 4.899 gallons of fuel at a cost of $4.899 a gallon. $24 bucks. 290 miles. 59.2 mpg. After my 4% COSTCO discount just under eight cents a mile.
    • Howdy folks,   Recently I pulled a heated steering wheel and clock spring out of a 2015 Sierra All Terrain (part numbers coming soon - will have to disassemble), and just installed it on my 2016 Sierra WT (as base model as it gets).   On install, I noticed that I’m missing the connector often tucked behind the dash for the heating element.     No problem… or so I thought.   I used an “Add-A-Fuse” at my heated steering wheel fuse location, which has voltage, but no wires. I ran it to the positive of the heated steering wheel (Violet/White), and took black to ground.   Hooked up the battery, turned the truck on - no heated steering wheel. No button backlights. Was pleased to see that my cruise control was working though.   Read a post suggesting reversing polarity, so I gave it a shot. Violet and White to ground, Black to power.    Aha! Heat! But I seemingly can’t turn it off AND still no backlights on any of the buttons.    Checked all fuses, everything is still in good order. I’m stumped.   Does anyone have any insight? If so, please share!
    • I'm about 1800 miles into my last oil change, and yesterday a message appeared saying oil life was at 77%. Not sure why it popped up but I think all of these electronics could be susceptible to solar flares or somesuch. I change my oil right at 3K each time, and that was the first time in 10870 miles that message came up. Strange thing is that it showed on the screen at all since I don't drive with that sort of info displayed on the DIC.
    • I’m praying that someone sees this and can help me out… pulled a heated steering wheel and clock spring out of a 2015 Sierra All Terrain, and just installed it on my 2016 Sierra WT (as base model as it gets).   On install, I noticed that I’m missing the connector often tucked behind the dash.     No problem… or so I thought.   I used an “Add-A-Fuse” at my heated steering wheel fuse location, which has voltage, but no wires. I ran it to the positive of the heated steering wheel (Violet/White), and took black to ground.   Hooked up the battery, turned the truck on - no heated steering wheel. No button backlights. Was pleased to see that my cruise control was working though.   Read a post suggesting reversing polarity, so I gave it a shot. Violet and White to ground, Black to power.    Aha! Heat! But can’t turn it off AND still no backlights.   Checked all fuses, everything is still in good order. I’m stumped.   Does anyone have any insight? If so, please share!
