50 minutes ago, Rodney Goins said:
2- 2023 duramax trucks both less than 60,000 miles one was in shop for month 2nd one still in shop over a month and waiting. Have driven 6 speeds never touched with milage in the 500,000 miles no problems and better fuel milage time to go back, because ford amd dodge went to more gears doesn't mean you need to match stick to what works
Our team regrets to hear of these concerns you are facing with your vehicles and would like to help investigate further on our end. When you have a moment, please send us an email to [email protected]. Be sure to include your Username and Forum name in the subject line with additional details. We will watch for your email.
    ShowMeShooter1332
    ShowMeShooter1332
  • Who's Online   1 Member, 0 Anonymous, 5,964 Guests (See full list)
