Nice install. I have the same boxes. Having a problem finding a tonneau with clamps that will fit.
What mods did you make to get the tonneau to fit? (if you don't mind me asking...)
Edited by Larry Walinsky
What kind of cover are you getting? I ended up trimming the box gasket on the front and back and didn’t install the middle clamp. I can post pictures of where I relocated them tomorrow. I also have a bed slide I am waiting to install. I want a 1/4” aluminum diamond plate top with a removable center piece to still utilize my gooseneck.
On 8/16/2020 at 12:19 PM, Denali_Brad said:
I looked at these in the dealership yesterday. They don't hold much at all.
They actually hold a decent amount
Looking to install a Gator FX Tonneau cover. It's a trifold hard cover. The clamps are a bit too large/tall. I was considering heating and reforming the box top locations where the clamps would be positioned - or - finding/fabricating new clamps.
Which cover did you install?
Pics would be great, thank you!
I went with the truck fold rough country. My buddy told me a bakflip would have fit without mod. The cover too but they are 500$ more than the rough country. I don’t have pictures of what I did to the cover but on the front section (closest to the cab) it had 4 clamp down brackets. I removed the two further away from the cab.
Then I slid the clamps to each end of the box and had to cut the gasket on the box. I nipped the corner of the gasket off for the back of the box but towards the bed I had to notch out a few inches. The boxes have inner seals and I have the cover so I am really not concerned about the trimming. I was also thinking of re-drilling the holes in the boxes to drop the boxes down but it would have maybe given me 3/4” and I probably would have still had to do these other thing so I never did that but might work for you.
I just posted them, hope they help
@Dcalvey
Was it hard to modify for the top? I was looking to get the side storage and a hard rolling top for my sierra 1500 but can't find much information on if these will work well together if at all.
Thanks,
Troy
    Enduro73
    Enduro73
  • Who's Online   5 Members, 1 Anonymous, 1,387 Guests (See full list)
    • This can be done.  It is not cheap and requires an instrument cluster swap with custom programming, new steering wheel with the controls on it, and a special jumper harness.   The cluster upgrade - 12.3” Digital Cluster Upgrade – 2022.5–2026 Silverado / Sierra (T1 Refresh Pickup) - WAMS   The wheel upgrade - Steering Wheel Upgrade Kit – 2022.5–2026 Silverado / Sierra (T1 Refresh Pickup) - WAMS   The column harness upgrade - 2019 - 2026 Silverado / Sierra: Steering Wheel LIN Bus Harness - Harness Dr. - DIY Done Right     The problem with doing all of this?  You pretty much can't have any programming done to your truck that involves the cluster ever again.  The dealer won't be able to program the cluster as GM's system will only pull data for the cluster the truck came with.  So it would be advised also to turn off over the air updates.   TLDR;  Should have bought an LT double cab?  You'd have a power seat, the wheel controls, the cluster, all things that you've been seeking in your various posts so far about your new WT regular cab.
    • I was unaware of that, thanks for updating me.
    • Yes.  The 2.7 Turbomax has Active Fuel Management.  It is NOT the same as the V8s.  Totally different system.     Here is an article from GM when the 2.7 came out explaining the cylinder deactivation and the valve lift system.  Starts at the section called "SCS Valvetrain":   New Turbocharged 2.7L 4-Cylinder Engine Powers Full-Size Trucks – TechLink         This is an internet myth going around.  It was alleged that some 5.3s had this mystical 8th digit of the VIN as an "E" which somehow meant it had a new one year only 5.3 that didn't have DFM.  The writer of said article and the person that made the claim conveniently can't count because they posted the VIN.  The 8th digit was a "D" which meant its still the 5.3 with DFM.  The 9th digit of the VIN was an "E" and the 9th digit isn't the engine code.  At all.
