Service Trailer Brake System
I bought a 2014 GMC Sierra new off the lot. Within months of having it I got a Service Trailer Brake System alarm intermittently and it wouldn’t stay constant. I brought it to the dealership and they couldn’t do any troubleshooting without an alarm code, same as with the power steering issue. Over the years the alarm has become more persistent. My trailer brakes and lights have never had any issue and all the connections and cable runs look good. Any advice on here to stop the alarm? Any help is much appreciated.
Common problem on these trucks my 015 does it on occasion with or without a trailer hooked up. On mine if I cycle the slide lever on the brake controller it will go away so I haven’t messed with it yet but I’m sure I’ll have to sometime. I did some research on here to find the cause and found all kinds of possible “fixes” in the 20 plus threads. Some guys have found that swapping one of the “control modules” (not sure what it’s really called) above the spare tire fixed it others say swapping the controller worked for them and some say it’s in the wiring/pin fit of the connectors.
The search function on this site SUCKS IMO but if you type this into your google search
2015 silverado trailer brake warning site:www.gm-trucks.com
you’ll find most of the threads on here. Lots of good info in them already.
GOOD LUCK.
I have the previous generation but have no alarm but a warning message when things with it were not right.  Anytime that message appeared on the DIC there was a trouble code stored in the Chassis Module.  Basic code reader is not going to see it.  There's but three parts to these things, the controls on the dash, the SSR relay and ITBC Module.  Well, the wiring too.  Dirty wires can set off codes.  In my case, it was the SSR that needed changing.  It first started acting up soon after crossing a deep stream.
  • 2 months later...
GOOD LUCK.
I appreciate the reply on this. I’m going to look at these things. Thanks.
I appreciate the reply. Haven’t dove into it yet but will definitely update this thread when I figure it out. Thanks.
    DaleB
    DaleB
  • Who's Online   1 Member, 0 Anonymous, 1,266 Guests (See full list)
    • My truck is a ¾ ton but my placard also says 80 for the rear tires, I think I might have the upgraded suspension to the 3500 series maybe.   I put my air down to 60 and the light was still on, and there was no way I was putting over 60 psi in the rear empty and not towing because I knew the actual number Toyo gave me and I didn't wanna ruin the center of my tires!   And you actually can change it in the settings from metric or is and it will show kph or mph then when you go into your tire settings it will be either psi or kpa, but it would be nice to just change it directly on the tire psi page
    • Common Sense Assembly   Your driveline is forgiving of the occasional mistake. It will even often forgive the random serious blunder. But it will not forgive a continuous bad habit.      What? Not everything needs to be a five thousand word essay.
    • We drove about 15 minute east today to visit a friend and saw a steep increase in price in the same county. About 50 cents a gallon steepper.
    • Sure about that? A degree wheel and a dial indicator would lower your degree of assurance in that statement. 😉    It why we have offset keys and dialable timing sprockets. Just say'n.... I've built a few and have never seen one "On the money".
    • I will admit I haven't experimented much with pressure drops beyond the numbers I put in and part of that is that the numbers I used are fairly low and then found out it would trigger regardless at that 35 psi. Having said that I had tried before had changed the placard pressures and being that I have a 1 ton set to 80 on the placard for the rear I believe it triggered close to 60, the front I don't recall now for sure but thought maybe it could get close to 45 from that factory 60 placard pressure. So I never did figure out if it was a number of psi from placard pressure to the alarm or a percentage of the total placard number as some figured it was like a 25% drop from placard pressure would trigger it. So as to try and answer your question, I believe I set the placard pressure on the front to 47 or so and while I run the front tires at 40, they have dipped below that some if its colder and I haven't put "winter air" in yet and never once have had the front alarm go off. I would say that the answer your looking for is no, that if you set your placard pressure to 45, you have a certain amount of room to drop below that pressure before the alarm will go off.    The pressures you decide to run in your truck, that ends up being what makes sense to you based on what your carrying in your truck or if towing, then have to bump them back up to something that will carry the load in the rear and the fronts typically left at the same pressure. It all comes down to that chart I put the link to and using an accurate roadside scale to be your guide, both unloaded and then loaded to know your minimum safe pressures.    I just wish GM would allow a person to change the readings for the tire pressures to the English system of pounds as I have to look at that goofy metric reading that will never ever jive in my head and will go over and change it just to figure out what they are if need be and then change it back.
