Leveling Kit Options for GMC Sierra 1500?
Trying to decide what size front leveling kit to put on my 2014 GMC Sierra 1500 4x2.  Only trying to raise the front end up some to make sure I can get a 33" tire on there without rubbing.
I would rather proceed with a size level that if anything still leans forward slightly verses one that kicks the front end up higher than the back.  I have seen that on the road and do not want to look like I'm driving uphill the whole time.  I've seen posts and videos that say a 1.5 inch, 2.0 inch, and 2.5 inch kits got their Chevy/GMC 1500 trucks perfectly level.  I'm leaning toward the 2 inch RC or Motofab, but was hoping to get some opinions.  Not sure if the 4x2 vs 4x4 makes a difference here with the size.
Does the lower strut spacer vs upper strut spaces make a huge difference at all?  As mentioned above, I am assuming these options would allow for a 275/60r20 AT tire to clear without any issues, but If I'm mistaken I'm all ears for suggestions.
Thanks.
On my 2015 I did the 2 Motofab lower and the rear was still higher than the front. When I took out the rear factory bocks it was perfectly level and sometimes looked higher in the front. I think the rear block was 1.25.
2014 you shouldn't have any problems, with 275/60/20 even with out a level, it's 2017/2018 where you get into rubbing issues due to the stamped steel control arm.  Luckily you don't have to worry about this.
    bellssn690
    bellssn690
  • Who's Online   1 Member, 0 Anonymous, 817 Guests (See full list)
    • This is a really late reply but I just found this thread. They won't sell the hinges. I've gone 7 rounds with them. Their solution is to buy a new cover. I'm about to buy a new cover and it won't be a Bakflip. It also won't be from realtruck.com.
    • Yes, and also pulling heavy trailers or a large camper up steep grades as well as descending grades such as the more rustic off road camping locations and using engine braking with that low gearing as well as soft ground can just suck the power . I realize pickups these days tend to have an over all lower first gear ratio compared to automatic transmission pickups from years back so that has helped a lot in its ability in high range but there comes a point if in four wheel drive the torque runs out at the wheels, certainly with a gas engine. They don't put two speed transfer cases on pickups for a cool factor, they have a function if one needs that massive torque to the wheels that high range can't deliver.
