Patrick H
Hey guys, does anyone know if the 6L80e in a 2018 1500 is the same transmission that a 2018 HD has, both with a 5.3 engine. If the transmissions are the same then why does the 1500 have a transmission thermostat & the 2500 does not. I have been told that reversing the trans thermostat will not harm the transmission, why then is it there. Heat kills a transmission & I don't want to kill mine by doing the wrong thing. If anyone out there has deleted theirs & driven with the deletion for a long time please respond to this.
A 2500HD truck use a 6.0 gas engine or a 6.6 Duramax Diesel. There are no 5.3 engine options on 3/4 and 1 ton trucks.
The 2500HD's also use a beefed up version of the 6 speed auto, they are the 6L90e which has different parts than the half tons 6L80e.
The heavy duty trucks are also a bit different in the generation of engines and computer controllers. Port injection verses direct injection in the half tons (2014+ with EcoTech3 engines).
Reversing the thermostat won't harm it. Yes, heat it bad for the fluids but you have to be constantly at or above 220º for it to severely reduce the life of the fluid. Running around at 180-200º is completely normal with a working thermostat.
    rayredbone
    rayredbone
  • Who's Online   1 Member, 0 Anonymous, 515 Guests (See full list)
    • Thank You.   So far my new ride is making me look like a genius for going with the 3.0L, as my first fuel refill occurred over three weeks from when I took delivery.  This engine combination is very amazing.  So far no issues and had not done a regen yet.
    • I am curious as to how much fluid you put back in the transmission ( assuming you had replaced the filter to compare to my findings ) and then went through the process of warming up the trans before pulling the check plug to drain out the excess and if you measured how much came back out.    I just found it surprising that some claimed a certain amount less fluid being put in and then draining some back out. The attitude of the truck as per if the surface is level and how the trucks stance is would make quite a difference since the check plug is right at the front of the transmission.
