What do I have?
1. Specifically what rearend do I have? I know the diff cover has 14 bolts but is it the 9.5" or the 10.5"?
2. what front diff do I have? I have no idea....only that its IFS.
I looked at the RPO codes and that didn't tell me what specifically, what it did say was (I think) the drivetrain was rated HD for 9,900lbs or something like that.
thanks
Take off your center caps on the rear end. If you have a hub sticking out you have the 14 Bolt FF 10.5 if not you have the 14 bolt 9.75"....you can also tell by how pointed the bottom of the pumpkin is.. the more point one is the 14 FF the more rounded 12 bolt looking is the 14 SF..
You have a 14bolt 9.5 rearend. I was trying to figure out mine and the I called the stealer and I gave the service guy my vin# and he told what i have. If you are still curious call the dealer and ask parts or service. good luck.
The 14 bolt semi floater is a fairly strong rearend. It was used on the light duty 3/4 ton trucks. I had a 99 chevy Z71 with the HD chassis package that came with the 9.5" 14 bolt semi floater. I think chevy uses it on trucks up to 8600 GVWR. It's a lot better better than the little 1/2 ton 8.5".
I have a 10.5" 14 bolt FF in my truck. As you can see from my sig, truck has a 5 spd stick in it. This is the only time a 8600#GVW 2500('99 to present ) will have such a rear end.
    • "Teardown" is complete. Head surfaces are clean and ready, new intake is prepped and ready. Coolant drained and water pump is removed, radiator is removed, new hoses and pump are ready.   The replacement intake is also from a '95 (with I think 260k, the odometer said). Noticeably less pitting where it covers the rear coolant passages. I'm not sure if that's a tribute to more frequent use, more frequent coolant changes/upkeep, or if the intake was machined at some point. But it appears I found a good one.   My coolant hoses were original, and the lower hose still retained the factory spring inside. It's not really rusty, but it's got deposits all over it. Unsure if I should re-install it (will thoroughly clean it first). Someone said hose technology has gotten better since 1995 (has it?) and I don't need the spring. I think modern EPDM is what made those hoses last from 1995-2026, so it's a question of how much suction can the water pump really pull, and will it collapse the hose without a spring?   I'm stopped and waiting for parts, however.   When I first brought the truck home, the fan was intermittently hitting the radiator shroud. I could see someone had monkeyed with the shroud (put a bunch of cardboard as a spacer between the upper/lower shroud halves. Someone said the motor mounts have likely failed and the engine has sagged. I wasn't sure I believed that. The engine is really solid in its mounts: To remove the old intake I *just* nearly permanently welded to the heads with freshly cured RTV and gasket snot two weeks ago, I literally had to use the arms on my lift and a chain with a bolt attached to the intake to pull it loose. It almost picked the front of the truck off the ground before ....scuuuuuuuuuuup.... I could actually hear the gaskets tearing and it broke loose and the whole truck settled back down. Motor barely moved.   SO, those parts I'm waiting on... The lower radiator mounts/bushings had completely failed. The radiator needs to be insulated from the rad support, and the bushings help the rad stand at the correct height. The plastic "baffle" was also destroyed at some point. Someone had attached the shroud to it incorrectly, overlapping a joint that should have been underlapped, creating another suspect issue potentially causing things to hit the fan. Broken tabs, side is busted off, and it's perma-formed/bent where it was jimmied incorrectly.   The baffle? Unobtainum. Long since discontinued from GM, of course. Aftermarket/capa/chinese? Also unobtanium. In GM's infinite wisdom, it appears there are at least two different variations whether the Blazer is 2 or 4 door, and I can't yet tell if they shared the same part with the S-pickups. Plan B, if I can't find a viable used one, will be to create a bracket to re-assemble the critical joint I need to seal a gap with the shroud. But that will bug me, it won't be...perfect.   The water pump bolts appear to have been installed with...plumber's putty. I guess, sure, if it works...? I've found a few "backyard fixes" like that. Someone's been here before....   If I can't find someone to jam bamboo under my fingernails to fill my free time this week I think I'll install the driver's power window motor and replace the rear door speaker that's inop. I've got a genuine GM "9.5" ohm working replacement. Why GM used a non-standard resistance....nevermind. Of course they did, you can get more sound from a cheap factory amp that way.   And the saga goes on...
