2018 Sierra mirror dimming with topper
Mercracing
It took me longer then I care to admit to figure out why my mirrors are not dimming. Cuz I have a topper. There must not be enough light hitting the sensor in the rear view mirror to make them dim. Has anyone moved the sensor to the topper or somewhere else for it to work as it should?
Thanks in advance and Merry Christmas!!
Belated Merry Christmas!
What is a "topper" in a Suburban? Or are you talking about a canopy/shell on a truck?
Nothing Suburban related on this one. All Sierra. Yes, I mean a canopy/shell on a truck bed.
My current best idea is to find out what wires are for the sensor in the mirror and install a resistor up there so they always dim when the auto headlights turn on.
Good luck, looks to be a bit of work involved (not our mirror, but good example video).
    contrabombarde
    contrabombarde
  • Who's Online   3 Members, 0 Anonymous, 842 Guests (See full list)
    • I'm sure if you went to a junkyard where you go in and pull the part off the truck yourself, not a used part place where they do it for you, you can get that part on it's own.  Depending on if and what else you would be buying, and time of day, they might even just skip over adding it as a item to the bill.
    • No, we trade them like pokeman cards.
