Hi guys, yesterday I had to replace both batteries in my 2015 Sierra 2500hd diesel. It was straight forward and easy, but after replacement  my Amp Research power running boards stopped functioning completely. I double checked the fuse was good, I double checked the ground was good. But still no operation.
Does anyone have experience with this?
Perhaps needing a reprogram?
Thanks to anyone with info!
Having the same issue in my girlfriends truck. 2017 Silverado rocky ridge. Battery died, so we had it replaced and now the amp research steps will not work. Ever find out what it was?
blown fuse.  replace the fuse.  its clear color fuse in the red compartment.  you should be able to see it when you pop the hood towards the battery on passenger side.
That happened to mine as well.  The fuse wasnt blown.  I just took the fuse out and put it back in and it fixed the problem.
  • 9 months later...
https://youtu.be/RRkhi9RoRe8
Here you can find how to fix the steps by removing the fuse. In the comments there’s one posted by Sam C. :
“Everyone driving a GMC with this problem. I did the fuse thing, didn't work. Look through the internet. No
solution. What worked for me was to unplug the module beneath the steering wheel. I then opened all the doors on the truck. Then I turned it power on.
Didn't have to turn the engine over. Then plugged the module back in. Then closed all of the doors. And it worked.” Hope either solutions solves it for y’all.
  • 5 months later...
I had this same problem with my 2013 Silverado after disconnecting the battery for another issue. I pulled the fuse, cycled ignition on then off. Replaced fuse, and steps started working again.
I took the fuse out and put it back in. It's the red fuseholder that goes to the positive + post. That's all it took
    DM22
    DM22
  • Who's Online   3 Members, 0 Anonymous, 2,301 Guests (See full list)
    • I thought I would use your thread and add to it as I just did my first longer drive with my truck in the last couple of days. I drove from the Grande Prairie area of Alberta down to Edmonton and most of where I drove in the city was the ring road so fairly free flowing but a bit of stop and go as well in the city. Stayed the night and returned home and not too many stops along the way each way but every restart and certainly every cold start sets it back for fuel mileage. Why I say that is I see some people will cherry pick a fuel mileage leg after the vehicle had been warmed up driveline wise before hand and its a forgiving ( easy rolling drive leg for example ) and call that their fuel mileage which can give a false perception of reality. I was not heavily loaded at all but never the less the flip bak cover, rubber bed mat, various tools etc and extra jerry cans of fuel all way up to a few hundred pounds of dead weight so its not an empty truck. The cold inflation tire pressures are set more near the freezing point so once they are warmed up driving I was showing 45 front and over 40 rear and realize high inflation pressures would help a little in fuel mileage but certainly not the ride on our crap sections of highway. The weather was good so was not raining as that can really drag mileage down, in fact I had a bit of a tail wind on average driving home. Most people on here would never have driven on that freeway to visualize it but its got a fair bit of rolling type of landscape with numerous river valleys. For the most part I had it on cruise set to 62 although kicking it off if I caught it in time before it started down shifting and self braking going down the grades. Most of the more substantial grades its shifting into 7th I believe as 8th just doesn't have it. Total distance round trip was 643 miles and my overall average and I did refuel three times in all, figured out to 17.65 miles per US gallon. My best fuel mileage section refuel within all of this figured out to 18.46 and these are all hand calculated figures. I find if anything that the trucks computer can be over optimistic, sometimes its pretty close but other times its stretching it. On paper persay in theory the truck would have just about made it on fumes for that whole drive without refueling once.    Which made me think of the topic thread of the wonder if these trucks could do 20 mpg and that is a good question, certainly would have to be on an easy going flat highway, no head wind, the right temperature, not packing around a bunch of dead weight and puttering along even slower than I was I would suspect and going steady and not stopping to smell the flowers or take a piss !. It probably is possible but not without effort to attain that with the wind resistance and weight of these trucks. Of course on my drive most people are passing me if they have the power as per loaded highway tractors, never mind a lot of speedy vehicles but the speed limit is 68 and most are at or well over that.
