Horrible fuel mileage please help
I know this topic has been beat to death, having to move soon and with the gas mileage I'm getting, I might have to sell the truck,  so I have a 99 silverado 1500 4x4, with a 5.3, getting 9.5mpg, it has a custom tune on it, new o2 sensors, cleaned maf sensor. New plugs,  fuel filter,  full synthetic fluids all the way around, swapped to electric fans, ran seafoam in it countless times, clean throttle body, no dragging brakes, I've rebuilt the entire front suspension, new u joints, 3.73 gears, 34 inch tires, havent seen any vacuum leaks, fuel trims are within spec, compression is perfect, fuel pressure is good, I'd be fine with 12-13 mpg, but even when I had stock wheels and tires with a tune. I still only got 9.5 mpg now I have 34s with a tune and oddly enough. Still gets the same mileage, what can I do to bring it up a little bit, its killing my wallet, i see all these other guys on 6 inch lifts getting 15mpg and i cant even break double digits
    appletrav
    appletrav
  • Who's Online   2 Members, 0 Anonymous, 393 Guests (See full list)
    • 2013 5.3 still to this day calls for the PF48 filter.  Which as a 15psi bypass pressure.     There is a TSB, 17-NA-157 that talks about the PF-63 and PF-64 filters which have a higher bypass rating of 22psi.    TSB HERE - temp.xml   "Beginning in 2012, the oil pumps began to regulate main gallery feedback instead of pump out pressure. This means that the oil pump now does not begin to regulate until pressure is built up to the main gallery. This change reduces the amount of time it takes to provide oil to the engine bearing and lifters during extreme cold start conditions.  Main gallery feedback oil pump control systems are present on the following engine families which use Spin-on oil filters: Small Gas Engine (SGE), Large Gas Engine (LGE), High Feature (HFV6) Gen2 and Small Block Gen5 gasoline engines. These engines with the main gallery feedback oil pump control systems are factory built with an ACDelco® oil filters"   It also calls out what engines use those filters.  The gen 4 small blocks were not on that list (LMG, LC9, L9H, L92, L94, L20, L96).  Gen 5 small blocks use the higher pressure filter.
    • To me it honestly makes zero difference what filter you run. It's not a race engine, just a truck engine that's mostly bumming highways and it just needs a filter that filters oil.   The filter used to be a 7060 and the long version was a 7045. Now it's the newer updated filter that the K2XX trucks and newer run, the 100255 I believe if we are using napa numbers. Any of those filters is going to do the job.   I wouldn't overthink it, to me it makes no difference because those first filter numbers worked for 18+ years before the spec suddenly changed.
