2 hours ago, Robotaz said:
Yeah I’m just wondering if the brake software is part of the ECM tune. Used to brake software went to its own module, similar to the tranny.
I honestly have no idea... this truck is still new to me and I don't know a ton about it, yet.
  • 5 months later...
  • 6 months later...
I just had a similar experience with my 2019 Silverado RST. I ended up with a clicking noise from the right side of the engine. Turned out a drive rod on the right side somehow got bent and the vehicle showed a history of misfires. They replaced it under warranty and 2 days later (just now as I'm looking this up) I pulled out of my driveway after idling my vehicle for about 5 minutes and I had the misfires again for about a full block until I got to the next intersection. From there it didn't do it the rest of my 15 minute trip to work. I'm going to call the dealership again to explain that it's still misfiring. It's doing it only when it sits for an extended period of time in-between uses in this colder winter weather.
    • 2023 GMC 3500 HD, SLE, 6.6L Gas, 4x4, 6 Spd Options:  SLE Convenience Package; Driver Alert Package 1; Spray on Bedliner; X31 Off Road Package; TRAILERING MIRRORS, HEATED POWER -ADJUSTABLE, AUTO DIMMING, WITH TURN INDICATORS WHEELHOUSE LINERS, REAR INC. REAR AXLE - 3.73 RATIO INC. GVWR, 11,350 LBS. (5148 KG) INC. FRONT AND REAR PARK ASSIST, INC. ULTRASONIC     I have been launching my new boat and noticed some things related to the parking brake.. I usually set the parking brake (habit) when on flat ground for typical driving.    When backed down on the launch ramp to launch the boat and I place gear selector into Park, the parking brake activates automatically. My second nature is to set parking brake manually and noticed I was turing the parking brake off.  The parking brake appears to be setting itself automatically.   I looked all over my owner's manual and only found references to being on an incline and manually setting parking brake, or at times parking brake will be auto engaged, but nothing specific to my situation.    When is the parking brake automatically engaged?  Under what specific circumstances?  Can the auto set parameters be changed?     I like the auto set feature.  It would be nice if always engaged when shifted into Park and released when shifted out of Park (like my wifes 2025 RAV4).   Thanks!
