2014 gm rims and sensors on nnbs
is there a tool or a way to make it work? or are they different frequency ? I got 2018s on my 2008 just tpms light on
On the 2008 you van air out the tires for a few seconds instead of learning with the tool. The 18s will definitely work in the 08s (same frequency). Follow the instructions in the owners manual.
2 hours ago, Pinnacle said:
Cant get it to work really pissing me off.
Well, all we know if that you're driving some year GMT900.  From 2007-2009 they only used 1 frequency, 315 MHZ.  Then in 2010, 433 MHZ was added along with it's own RPO code (which escapes me at the moment).  And in 2010, the method of programming changed.  With the earlier setup, one can reset the sensors by lettting air out of them, or use the 50448 tool.  With the 2010+, you have to use the 50448 relearn tool.
So, what vehicle is this?  What is the part number of the sensors you are trying to use?  What is the frequency of the sensors and what is the frequency of the truck?
I got 2018 sierra rims  and sensor s on my 2008 sierra.  letting air out method doesnt work, i assume the 2014 up trucks use a different frequency
Ok, well your Sierra will have 315 MHZ, the new wheels could be either.  Do you know their part number or code?  Have you done the relearn procedure before on your truck, are you familiar with it?  It's a pain letting the air out to set them and then having to air up the tires again so the truck will ride right.  The $10 tool is the best thing since sliced bread.
Once you establish that the correct procedure is being followed and still not working, and you have no way of knowing the part number because the tires are already mounted, you may just have to go out and buy new ones.  You can often find fleet take offs for a fraction of the price of new on Ebay but beware of Chicom knockoffs, they are junk.
25920615 and 13598771 are known to work on yours.  Even Chrysler 56029398s will work!  Somewhere around here I posted a list of other PN#s over the years that will work.
Ive done the relearn 100 times on these trucks, Im not sure where you see this tool for $10 I cant find one for that.  And now no way of me knowing the part numbers tires are on.
I paid $10 and then found them for $8!
https://www.amazon.com/VXDAS-EL-50448-Pressure-Monitor-Activation/dp/B072BK693N/ref=sr_1_3?crid=20AZY31JB0G7Y&keywords=tpms+relearn+tool&qid=1578441263&sprefix=tpms+re%2Caps%2C173&sr=8-3
Ebay for less.
If you are that experienced with it, I think it is safe to say that the sensors are the wrong frequency and you'll need new ones.
Ebay for less.
I think they are
took your advise and ordered some 13598771 GM Original Equipment Tire Pressure Monitoring Sensor TPMS
    appletrav
    appletrav
  • Who's Online   2 Members, 0 Anonymous, 356 Guests (See full list)
