Fluid amount
Trace Reiter
We just changed the transfer case on our 2003 Chevy 3500k and was wondering how much fluid to put back into it. Some sites say 2 3/4qt others say it will hold 4.4qts. Which is correct
Gas or Diesel?  What TC, .Identification: check tag on case.
Could be either 4 pints or 4.4 pints depending on what TC (4 used) is in the vehicle.
NOTE-Pints NOT Quarts
    • My brother has an Escalade. The warranty has expired so he told his wife to go to the Valvoline quick lube he uses some times. They told her if her car was a 2020 and newer 6.2 engine they wouldn’t touch it. Hers is a 2019, so they did the oil change.
