2014 Silverado 4 wheel drive
Ron Deitz
I recently purchased a used 2014 Chevy Silverado I have an issue with my 4 wheel drive turning of anytime my tires lose traction. Have no clue as to why this is happening. Took it into the dealership I got told they reset the computer no issue, get home next day same issue! Looking for option!
    contrabombarde
    contrabombarde
  • Who's Online   3 Members, 0 Anonymous, 1,376 Guests (See full list)
    • Still looks like a rivet to me in the pics, I don't see a nut and none of the pics show the head of the screw. But if you says so.....
