Hi people, I have a question for you please. 2000 Silverado 5.3L. At -30°C(-22°F) after being plugged in all night the truck will crank over good with 60 psi fuel pressure but has no spark. Disconnect the negative battery cable for 30 seconds then re-connect and it'll start right up after about 2 revolutions.  I have replaced the PCM with another used one but same problem exists. Thanks for any suggestions.
13 hours ago, Duelin said:
Do you get a RPM reference on your tach while cranking?
I have never watched the tach while crankkng but will sure start. As for crank sensor; does it make sense that disconnecting and reconnecting the battery would smarten it up? I have yet to see a crank sensor code. Problem is truck starts fine until -30 when I’m trying to get to work so not the best time for troubleshooting. And I leave before the sun comes up so would be even more fun. Was just hoping that someone had the same problem and new exactly where to direct me. Thanks for the replys.
Two years later and still have this problem.  It shows 120 rpm when cranking. Block heater plugged in all night and scanner said coolant at 5C and IAT -25C. I think all this is for fuel management and not ignition spark though.  The last thing I tried was swapping around the starter and ignition relay but made no difference.
Keep trying it as long as the battery holds out and suddenly it starts perfectly.
What else is in the ignition circuit?
Thanks.
    btm
    btm
  • Who's Online   0 Members, 0 Anonymous, 1,387 Guests (See full list)
    • Can ask that about a lot of places.   Holiday sells 91 for $1 over 87 octane. BP 93 is 80 cents. Amoco 93 is 80 cents Kwik Trips is $1.20 for 92 or whatever they have and $1 for the 91.   I know that this is not exactly same as what you are saying with the premium to premium debate of those two stations but why is there such a difference. Top Tier this and that, it's all BS. All the fuel comes from the same damn refinery, so give me a break.
    • Why does Mobil Premium cost 90 cents a gallon more than Shell Premium when their regular offerings are but pennies apart?
    • Was all the way down to $3.69 a gallon but then jumped back to $3.99 just because for some reason.   Diesel floats between $4.80's to $5.10ish a gallon. I even saw Diesel #1 for $6.09 today but nobody in there right mind even buys that in the summer.
    • Mine just keeps lagging or getting stuck on the reverse camera. When I turn off the truck, get out, and close the door it will still stay on. It’s very intermittent and I would not be able to duplicate the issue.
    • I was checking out fuel prices at my farm fuel retailer at their pumps and yes the farm price is a bit lower than the non dyed fuel and was glad to see that the regular farm gas price has dropped a lot from what it had been but what blew me away was the price of diesel as the spread now compared to before the prices went up earlier in the year, diesel was actually slightly lower than gas which was a switch from the theme the last number of years. However that sure isn't the theme lately and definitely not right now. The prices I will post are not from that retailer but just looking at gasbuddy for the main city in this area and instead of posting the lowest price someone found I will list the higher price ( and that may not be the highest price, just whatever someone posted on gasbuddy ).   So regular gas and there are a lot of stations listing the same price for regular is 1.68 a liter, premium 2.00 a liter. Diesel 2.03 a liter for a top price I saw on diesel.   Figures out to 6.36 a us gallon Canadian funds for regular and 7.68 for diesel. With the US exchange rate it would be 4.58 us for regular and 5.53 for diesel.    Thought I would figure that out to get a picture of what it settles out like compared to various US prices and its about the same as the current price in Fairbanks AK as Anchorage tends to be lower. So yes, these would be the prices and higher along the way on the Alaska highway where they know they have a captured market !, for fuel prices for those beginning the long drive back to the lower 48   The problem is our Canadian dollar and going to the states that have the high prices, boy do we pay then !
