4.3L engine swap
Can anyone tell me if I can replace the 4.3L in my 96 Cheyenne with a 4.3L engine from a 2001 truck without any major adaptations? Will the wiring harness and computer from my 96 make everything on the 2001 engine work? Thanks Wes
    Brendan C
    Brendan C
  • Who's Online   4 Members, 0 Anonymous, 986 Guests (See full list)
