Anything to look out for?
1911guy82
I'm looking at a 2014 Silverado with the 4.3 by with 55,000 miles. Sounds good for a v6 I guess. Anything to look for problem wise? I'm currently driving a 2011 f150 EcoBoost with 133,000 miles. Love the truck and engine but want something with less miles.
Just notified my 2020 dbl cab 3L diesel came in today, so my 2014 dbl cab 5.3 (70k miles) sle is available.  When new, dealer replaced most of the rear end because gearing was out of specs. Trouble-free since.  Line-X, leather, rear air suspension, soft, roll-up box cover, and running boards.
    contrabombarde
    contrabombarde
  • Who's Online   2 Members, 0 Anonymous, 1,389 Guests (See full list)
    • Still looks like a rivet to me in the pics, I don't see a nut and none of the pics show the head of the screw. But if you says so.....
