Rpm goes down slowly when I'm in 1st gear
When i put my truck in drive and push the the gas while going slow and staying in 1st and let go the rpm go down really slow but if i rev it while in park the rpm go down normal...is this a sensor somewhere or is my transmission going bad?
Is the RPM going down at the same rate as your speed, meaning do the speedometer and tachometer follow each other? If so, I think that’s the way low (1st) gear is supposed to work. Are you using the brake or just letting off the gas?
Just letting off the gas...when i step on the brake the tac goes down slow then after  about 900 it drops down normal speed.
    Charly
    Charly
  • Who's Online   2 Members, 0 Anonymous, 3,740 Guests (See full list)
