2003 4l60e what fluid?
hey guys! have a 2003 4l60e in my hummer h2. it has 240,000 km on it on the original transmission. i dont remember the maintenance history for the tranny between 2003-2015 i have no clue but i know around 2015-2016 ish? my mexchanic did a pan drop and put in some fresh fluid but i dont know if it was dexron iii or dexron 6. so now i want to switch out the fluid all 16 quarts or whatever thru the coolers lines but dont know what fluid to use. ive heard the saying that you should never switch to synthetics later on because it leaks, but i also read the 4l60 doesnt like synthetic as it is too slippery. i have no clue what the mechanic would have used 5 years ago, if dexron iii was still recommended for my truck then obviously that. but it seems like dexron 6 was released in 2006 ish and it superseded the dexron iii and is a semi/full synthetic as a minimum
now for the new fluid i am looking to use for 16 quarts, i dont know if i should try to find a regular non synthetic dexron iii which i dont even know if i can find, or just use gm's dexron 6?
my problem is this:
lets say the truck has dexron iii in it and when my mechanic did the pan drop, he found dexron iii and put it in
theres also the possibility the fluid was changed in like 2008-2011 ish and dexron 6 went in and then in 2015-2016 when my mechanic did the pan drop he did dexron 6
if it has dexron 3 in it rn then i will for sure just put dex 3 in it again but if its dexron 6, then i dont know if i feel safe going down to a dex 3, but i also read the 4l60e hates synthetics which makes no sense since gm basically made a synthetic fluid for it
any 4l60e wizards here
aha
    Sothpaw27
    Sothpaw27
  • Who's Online   3 Members, 0 Anonymous, 439 Guests (See full list)
    • Can it still be Assembled II?   Viscosity on the decline by various means. Heat on the rise making that worse. Engine RPM in the tank. Smaller motors with more boost trying to emulate an electric motor. Full torque, zero rpm. Then we will triple the OCI. Argh.    But wait....there is more. LSPI has pushed a shift from Ca to Mg and as that cost more PLUS the run to lower sulfur compounds the TBN is moving in the wrong direction for the increased OCI's demanded.    That not being enough to placate a demand for a parameter they can't measure the other sulfur bearing compounds are also under attack. That would be zinc and phosphorus sulfonate compounds. To some degree those are being replaced with boron esters and others, i.e. titanium ect. All of which have shorter service lives. And there there is the "Secrete Sauce" marketing for AW adds that 'Can't be detected by UOA's" but trust me because I (the blenders) never ever lie.    Spoiler alert; ALL additives are sacrificial! Smaller amounts of the old blended with less robust versions of the new do not equal longer service lives. So what are the blenders recommending? Wait for it.......   MOVING THE GOAL POSTS! OMG      Let's declare the long standing TAN/TBN crossover irrelevant and tell people that soot is a great 'graphite' based lubricant which can aid tribo films. Wait, what? Let's declare that the standards used for oxidation and nitration were to conservative and can be expanded. Let's tell them that because GDI fuel dilution, although being a VISCOSITY KILLER and an acid generator is actually okay because we have better base oils that limit viscosity failure limits. (Said knowing this is measured in fractions of a centipoise and in bases not commonly used in shelf oils)   Lying from the heart is not just the new normal but we have a public, a very young public, that is so ignorant of the facts and so sure of their "RESEARCH" into AI driven models base in regurgitated  instead of scientific research based unvarnished, peer reviewed FACTS that the incoming guard is loosing their grip on reality and the OEM's are tickled pink while the blends bend the knee.    You have an ever limited set of tools to work with. And sooner or later those will be taken from you as the API and the EPA strangle the last remaining fluids from the system. What you have left is your wits. If you care to use them.    At some point in the very near future it will not longer be possible to do "What is best for the machine", and be replaced with "The best you have access too". You WILL be rewarded with half the life and twice the cost. That isn't that hard to predict.
