2012 Suburban 2nd Battery
I know there are tons of threads on similar subjects, but I'm not finding answers that make me feel like I'm going to be able to get this going.
 I'm looking into adding a 2nd battery to my 2012 Suburban.  As technology changes, cars don't keep up!  I have several AUX loads that I want to keep powered with key off, but I don't want to drain my Optima starting battery (Damned RedTops don't like long term draws like USB chargers and the Stereo with key off) during park, and park and start short cycling (my wife drives 3 minutes to the kids school, then listens to the radio while charging her phone).  I want to run the entire truck off a deep cycle battery, while keeping my starting battery isolated from parasitic draws.  I'm basically hoping to stick the main battery wire running from the starting battery to the fuse block onto a feed from the AUX battery to run everything with key off from the AUX, but I'm having a hard time finding info on how to run the truck from the AUX battery.  I don't want to run the truck from the starting battery and a trailer or audio amp from the AUX battery, which is what these systems seem to be geared toward.  Maybe I'm over thinking this mess and should just hook a deep cycle battery to the Trailer post on the Fuse block and run a 7 foot ground back to the main battery ground post?  I'm worried about the computer being angry about voltages if it's drawing from the AUX.
It looks like the TP2 kit feeds specific additional loads directly from the AUX, not the typical key off loads that I'm trying to offload from the starting battery.  Help?
Basically, where I'm at is I can add a 2nd battery as referenced in several "Add TP2 to trucks without it" threads but I'm more worried about feeding the truck, than accessory loads off a trailer or plow from the trailer.  I don't want to rip apart any harnesses under the fuse block to feed the interior, I just want to power the X2 positive battery wire from a 2nd battery.  I was thinking about using a solenoid isolator or a diode charging relay and connecting the main fuse block to the saem side of the relay as the AUX battery and leaving the starting battery separate from the ECM, but from reading forums, the computer doesn't like not being connected to the starting battery.
A fella on the TYF forum just did something similar and posted about it with photos.  Our trucks were not made for AGM batteries and GM does not recommend them for the GMT900 platform.  You have to supplement your wife's driving schedule with a long highway trip or put the truck on a battery tender of some sort.
The stock battery is ACDelco's 48PS and the highest reserve capacity is the 48HPG.  It has an extra 25 minutes reserve capacity and has 56.3 Amp-Hours versus 45.8 for the stock one and weighs 8.4 pounds more.  My 48PS is marching towards its 4th year of service.
Talk to Bill, InTheBurbs. @intheburbs
I was not aware of the AGM thing with GMT900.  I have two trucks, each with 2 AGM batteries.  ?
I've had the two AGM batteries in my Suburban for over 5 years with no issues.
Here's the writeup I used, and added some additional information of my own.  All OEM parts, so it's as if the truck came with TP2.
The 2nd battery is isolated when the ignition is off, so all aux loads pull from the primary, and the secondary is held in reserve as the start battery.
https://chevroletforum.com/forum/tahoe-suburban-diy-useful-threads-61/aux-battery-tp2-upgrade-65109/
So, the referenced write up is what brought me to this forum in the first place.  My concern here is the battery isolation.  From everything I've read, the interior accessories still run off the main battery, the TP2 battery is only wired to the trailer power line and has a post on the positive AUX battery terminal for adding additional accessories.  I'm not looking to power an inverter or a stereo amplifier, or anything else with a new power feed; I want to power the interior accessories for the AUX battery, unless this the the reason for the small fused wire from the AUX cable that is meant to be connected to one of the 2 posts on the fuse block.
I'm not a mechanic, I'm an electrician, but 12V systems in cars are not my area of knowledge.
Not an electrician, just a geek who knows enough to be dangerous.  It sounds like what you want to do is the exact opposite of the way the truck is wired.
It would probably be easier and cheaper to just swap out the deep cycle battery and not try to swim upstream.  I have two AGM batteries (a total of 4) in each of my two trucks.  Have never had any issues in the last five years, and just recently, finally, had to replace one of them.  The only times I've even handled jumper cables or battery starters were to help others with dead batteries.
    MASONV88888888
    MASONV88888888
  • Who's Online   1 Member, 0 Anonymous, 1,544 Guests (See full list)
    • My 2025 Silverado 1500 had to receive a brand-new engine (long block) under warranty last month at only around 16,500 miles. Before the replacement, the truck repeatedly displayed "Engine Oil Level Low" warnings, even though the Oil Life Monitor still showed around 50% remaining after about 6,000 miles since my last oil change. After seeing the warning several times, I checked the dipstick with the engine cold, and the oil level was completely normal. The next day, the message escalated to "Add Engine Oil." At first, I assumed it was just a faulty oil level sensor, so I brought the truck to the dealership. After inspecting the engine, they found internal cylinder wall scoring and ultimately replaced the entire long block under warranty. Before this happened, I was planning to install a 4-inch lift and suspension upgrade on my truck. After needing a new engine at just 16,500 miles, I honestly don't see the point anymore. I also contacted GM to ask whether my vehicle qualified for a buyback, but I was informed that it does not at this time. Anyway, this experience has left me with serious concerns about the long-term reliability of this engine. I sincerely hope NHTSA expands the current investigation or recall to include 2025 model and performs a thorough inspection of affected vehicles. My biggest concern is that these engines may fail shortly after the powertrain warranty expires. If GM truly stands behind this engine, then at the very least, please consider extending the powertrain warranty to 10 years for affected owners. That would go a long way toward restoring customer confidence.
    • Without exception but then I'm the odd duck, right? I know what goes into that test, how it is calculated and thus how to beat it. But EPA values are often not beaten by the general public and the government has in past years adjusted the means and methods to come to those values to more closely approximate "Joe Average".    The only real trick to beating that EPA average is don't drive like "Joe Average".    It's the same method you used to profit from "Economic Migration" and in doing so beat the 'stats'. But you, like me, are not "Joe Average".     The thing you don't seem to grasp is this "Purchasing Power Index" isn't forward looking. It doesn't predict what it going to be but looks backward and states what it was. They are not telling us what the THINK, they are telling us what they MEASURED. Example:    Wife says "I'm going to lose 40 pounds by Christmas". May she does, maybe she doesn't but the doctors office who weighed her when she made that statement and again at Christmas only REPORTS what the RESULT was. You and I can banter about what was possible and what aunt Tilly did till the cows come home but the result is the result. Arguing otherwise is.....irrational. That's all I'm saying. This isn't about:      What you are calling a 'Statistic' is a RESULT not a CALCUATION and as a result the RULE. Like gravity as a rule, it can not be broken.
    • Just wanted to say thank you for posting this. Years later, your thread is still helping Silverado owners.   I bought my 2025 Silverado 1500 in January 2025, and I've had what feels like the exact same rattle since day one. After reading your findings, I believe my truck has the same issue with the cable carrier contacting the rear sliding window. To be honest, I had pretty much given up on pursuing the issue. It wasn't until I recently drove another brand's pickup that I realized just how quiet their cabin was—and how noisy mine has been all along. On my truck, the rattle happens on almost any paved road, gets even worse on rougher pavement, and I can even hear it during braking and acceleration.   I actually referenced your thread when submitting my case to GM, hoping they'll recognize this as a recurring issue instead of treating it as an isolated incident. The reason I reached out to GM first is because my dealership told me they would need to keep the truck for at least two days just to diagnose the problem. I was concerned that even after two days, they still might not be able to identify the source of the rattle before giving the truck back to me. I had also asked a few dealerships about this issue during previous service visits, but none of them seemed to know what was causing it or had a solution. That's why I decided to contact GM directly first, hoping they might already have an official repair procedure or guidance for this issue.   I also hope GM eventually comes up with an official fix for this problem. I have a feeling there are many Silverado owners experiencing the same rattle, but most either choose to live with it or simply don't know what the cause is.   Really appreciate you taking the time to document your diagnosis. Your post is still making a difference years later.
    • I have 2 choices.
    • Do you have access to BP fuels? Some stations have Silver 91 E-0 priced the same as their 93 E-10.  There is a local Marathon with 90 alky free for $6 a gallon but I go down the road to BP for $5-ish. They also have a 100 E-0 but that stuff is $10 a pop.
