Footwell lights?
Anybody added them?  I’m trying to find an easy way to tap into the o/h lighting circuit...
Any help would be appreciated!
ps- I went to the upfitter website and found the diagram but it made me even more confused. Ha!
Wish I had the truck to help u figure it out...but I will stay tuned while u figure it out lol
April can't come fast enough I want my truck
Sent from my Moto Z (2) using Tapatalk
Thanks for pointing me in the right direction!
I worked on this little project today and it's done.  Can't wait to see the results tonight- you can see the light a bit during the day so I think it'll be perfect at night.
The wire I tapped is in the O/H console. It's the grey wire from the passenger side plug- If you remove the plug and look into it, the wire is the very top right.    This allows perfect functionality for the new lights!  They dim, they turn on and off with the O/H switch, they work with every door.  In short, they work exactly like the factory O/H lights.
I ran the power wire across the front of the headliner next to the windshield.  Then I loosened the passenger grab handle and tucked the wire in there and down into the passenger fuse box,  Then I hooked up the passenger footwell light and ran the wire across the firewall to the drivers side footwell.  I picked up grounds under the dash.
Hope this helps somebody out!
So I guess that will help me but I think I will try finding that down under the dash instead of coming from up top...
Are the interior lights dimmable now???
 Nope
 Nope
Ok u mean they dim out when they shut off
Was thinking that was weird to have dimmable overheads
Correct.
Awesome post
Thanks for being the guinea pig
[emoji106]
So I replaced the strip LED's with some better quality pod lights.  Brighter, and a more accurate color match to the original lights.
You can see just how dim the interior lights are (they are on in the pics too!)   I also added one on the back of the console.  Nice addition!
 Very nice!  Where did you purchase those lights?  Do you have a part number?
Thanks!  They are the perfect color and brightness.
I got them on Amazon.  Partsam 4 pack LED rock lights part # GTCV-0256604321
    tblt44
    tblt44
  • Who's Online   1 Member, 0 Anonymous, 375 Guests (See full list)
