Pioneer double din 04 sierra Help
04 Sierra SLE 2wd (no Bose, no steering wheel buttons)
Just got a Pioneer double din unit. I also got a backup cam to go with it. I have wired single din several times but this is my first double.
For the new wiring harness,
where do I run the Parking brake wire?
where do i run the reverse wire?
First, I would suggest getting a wiring harness adapter, that just plugs into the existing plug in the truck, and can provide you with
-parking brake signal
-reverse signal
-enough power for the radio that you don't need a separate relay
-support for RAP
-all the audio wires
 Makes the install much cleaner and faster than hacking up the wiring harness.
I used the PAC-Audio RP3-GM11 when I installed a Pioneer AVH4000NEX in my truck with a backup camera, and swapped it over to my new Alpine ILX-W650 when the Pioneer crapped out earlier this year.
If you really want to hack up the harness, you can probably find the info you need at gmupfitter.com.
And if your pioneer unit is a multimedia/AA/Carplay style unit, note that Pioneer does 7 seconds of stupid every time the radio powers up, where it shows a warning dialog every time.  I do a lot of short trips every day with my truck, so it really annoyed me (I initially got another Pioneer when the old one failed), so I returned it and got the Alpine (which I think showed me a warning dialog the first time it was powered up, and hasn't shown another one since then).
Thanks for the response. That RP3-GM11 is a nice unit. I was thinking since i didnt have onstar, steering controls, bose or anything else "extra" that the RP3 wouldn't be necessary. If my head unit will work without the added module I would like to go that route.
For my Parking brake signal I think I can tap into the light blue wire behind the e brake.
And for the reverse signal I think there is a light green wire behind the main junction block (or near vicinity) that should show +12 power with vehicle in Reverse gear.
Then for the reverse camera I can use the reverse lamp wire (center pin?) on my 7 pin connector at rear of vehicle .
Could someone confirm this is correct or incorrect?
Davester, could you clear something up for me. Is the harness adapter a necessity?
Seems to me that its only required for guys who want to keep their bose, onstar, steering wheel controls, etc.
I thought I can use the provided harness just as I would for a single din install, only with the addition of parking brake and reverse signal. Correct me if I am wrong. I checked out that website you suggested but couldnt find anything to help me out.
No, it just makes the install a lot easier, and to get support for RAP, backup and reverse signals, and enough power for the radio.
that site has the wiring diagrams for your truck, so you should be able to find the wires you need to cut into to get those other signals.
    B07
    B07
  • Who's Online   3 Members, 0 Anonymous, 795 Guests (See full list)
    • Missing pieces of the Assembly   Detergency vs Solvency   Not the same thing. Detergency is the mechanism that surrounds solid particulates preventing amalgamation. Usually accompanied by a Dispersant whose job it is to keep those encapsulated particles in Suspension. Solvency keeps things that can be dissolved in solution.    Salt is a solid that can be dissolved. Pepper is a solid that cannot be dissolved. A detergent/dispersant is effective on pepper but a solvent is more effective on salt. As long as the solids remain in either state, dissolved or dispersed then they can be be removed with the oil upon change.    How many wranglers does it take to herd cats? Depends on how many cats your herding. How much sponge does it take to soak up water? How much water is there to soak up? Point is most oil blends start with some herding ability and next to zero sponge and recently even fewer wranglers are being sent to do the same job.    So you start with a dozen cowboys and zero cows but at the drive progresses you pick up cows along the way, but not cowboys. At some point you have more cows that the wranglers can handle and some leave the herd. Deposits. And the API has an acceptable number of cows they are willing to let loose. In the ideal world zero is the right number for he rancher but to the butcher....a few lost is fine. This cow is beat to death. Let's move on....   Solvency isn't something oils on the Walmart shelf care about AT ALL. Problem is, you motor does. Fuels driven varnish sticks rings and only a solvent can keep them in check. The bet is that the solids driven portion that plug the expander rings and the oil drain backs and VVT screens and AFM screens will be an issue long before varnish is. Not that it wont be but if they market well enough the consumer can be kept ignorant enough to either believe it is "normal" (A quart in 1 or 2K is normal) OR is kept at bay longer than the first owner is likely to hang on to the unit. Solvency cost money.    Now the OEM's have John Q. Public buffaloed into the belief that the number cows accumulated along the trail is a known and predictable CONSTANT. It isn't. Nor is the rate at which they crossed paths with them. Only the number of wrangles is constant. Or was. Each new generation of oil sees fewer and fewer of them.    So what happens when the number of cowboys is lower (lower TBN) with each seasons trail but the trial is longer (OCI) and the number of cows along that trail continues increase? (Conditions that promote deposits).    For awhile the blenders were on to something. Better bases are harder to degrade (fewer cows) but that was overtaken by a longer trail (OCI) and improved breeding (More cows) while continuing to reduce the cowboy staffing levels (TBN/Aniline #).    Marketing has been successful. We've fired most of the staff, cows breed line bunnies, the trail is ten times longer and we've convinced the boss his ranch is in better shape that it ever was.    That kids is just the cleaning side. The side few pay attention to.
    • Looking for this part for my truck. They don't sell just that one piece and to get it you have to pay over $100 even used for the whole air tube. The piece the hose clamp snaps into that is held on by the screw and nut. If anyone has access to one please let me know.
