Running board light kit
I just installed an LED light kit above my running boards. These had lights for the turn signals, running/parking lights and courtesy lights that come on when the doors are opened. I thought I hooked everything up correctly. The turn signal and courtesy light wires went to the BCM connectors under the dash. Black and brown connectors for the turn signals and the gray connector for the courtesy lights. I'm pretty sure that I got these correct. However, I could not find a wire in the BCM connectors that came on with the running lights. So I ran the wires up front and spliced into a wire in a harness connected to both head/parking lights. This wire had power when the switch was turned on and no power with the switch off. After I hooked it all up it appeared to be working like it should. Except at night when the automatic headlights come on, it turns my interior lights on. They will turn off if I turn off the switch but so do the headlights and running lights. If I disconnect either of the wires for the running lights or the courtesy lights the problem goes away. So where did I go wrong?
1 hour ago, Patrick Mulligan said:
Can anyone help me with this?
Have you checked with the company that made the kit, or gone on their website to see if others have had similar problems?
Maybe be more specific letting us know who makes the kit. You may be the lucky only one that has used this company, so replies might be few.
There are different people/manufactures on the site that can help if they know what they are dealing with.
    rayredbone
    rayredbone
  • Who's Online   3 Members, 0 Anonymous, 503 Guests (See full list)
    • Thank You.   So far my new ride is making me look like a genius for going with the 3.0L, as my first fuel refill occurred over three weeks from when I took delivery.  This engine combination is very amazing.  So far no issues and had not done a regen yet.
    • I am curious as to how much fluid you put back in the transmission ( assuming you had replaced the filter to compare to my findings ) and then went through the process of warming up the trans before pulling the check plug to drain out the excess and if you measured how much came back out.    I just found it surprising that some claimed a certain amount less fluid being put in and then draining some back out. The attitude of the truck as per if the surface is level and how the trucks stance is would make quite a difference since the check plug is right at the front of the transmission.
