Trans won’t shift out of first
My transmission in my 03 z71 went out so I swapped it with an 02. I don’t know anything about the internals but my friend said it’s been sitting for a while so he swapped the solenoids out for the good ones in my old trans. And he swapped the NSS . Transmission shifts good into gear and reverse . And when I first pulled it out of the shop it would shift into first and second but not 3rd . we went back out more fluid in it to where it was supposed to be but now it will not shift out of first manually or otherwise
maybe try scanning for codes from the tcm.  you'll need a better code reader to do it.
Is it the 4l60e?  Are you sure it's a compatible swap?  From what I've read, GM was altering the 4l60e all the time, so there was limited compatibility across years [I have no way to know one way or the other, just read that it's like this].
35 minutes ago, BlancoSilverado said:
Same issue when i did a swap on the Transfer case. make sure all the connectors are plugged in.
Everything should be plugged in. Which connectors are you talking about exactly
4 hours ago, BlancoSilverado said:
For me, it was the connectors on the top of the TC, i believe it was the speed sensors.
I just checked and everything is in correctly
Check your solenoid, sensors and wire harness. Do a search for 4l60e resistance chart.
Also check that the nss is properly installed and connected.
    ballencd
    ballencd
  • Who's Online   1 Member, 0 Anonymous, 485 Guests (See full list)
