Dash/Stereo lights in '98 Blazer
A few heater/AC control lights and stereo lights went out
in my 1998 Blazer. I ended up fixing them myself and thought
I would share it here.
These bulbs aren't replaced in the old conventional ways
and you can't buy them from the dealer. All they can do
is sell you a new Heater/AC control panel (like $300) or
trade in your stereo unit (more excessive amounts of $$$).
The heater/AC controls do use incandescent bulbs which are
soldered to a printed circuit board inside.
I took the assembly out. It was simple once the dash panel
was removed (not too bad -- easy once you know how).
I opened the assembly and found three burnt-out bulbs (out
of eight). Removing the bulbs required desoldering them.
This requires minimal soldering experience.
Luckily, Radio Shack had light bulbs which were perfect
replacements. They can be seen here:
http://www.radioshack.com/category.asp?cat...07%5F000&Page=1
(Refer to bulb in Figure 12).
Then, I decided to tackle the factory stereo which, too, had
burnt-out bulbs in the face. This was a little trickier but
still not too bad. You remove the stereo. Snap off the face
plate which will then swivel down (it is still connected by
several wires). Remove the knobs. Remove the nut and washer
on the volume control. On the backside of the faceplate, remove
about ten small hex screws to free the printed circuit board
from the faceplate. I used a power supply to inject voltage
to a bulb which then illuminated all the (good) bulbs on the
circuit board. I found five bad bulbs. I desoldered and
removed the bad ones. Then, I soldered in new bulbs (same
type as above).
Before, I thought I was losing my vision with my dash going dark.
Now, it looks like a Vegas casino.
It doesn't take a strong electrical knowledge/experience
to change these light bulbs. I recommend a low wattage
soldering iron to reduce the risk of damaging the printed
circuit traces.
To remove the solder, heat it up until it liquifies (only takes
an instant). Then, suck it up with a solder sucker or wick it up
with solder wick (like braided thin copper wire).
When resoldering new bulbs, use the standard 60/40 Tin/Lead
solder with rosin core. Do not use acid core solder.
You can use a 9 volt battery to test the bulbs right in the
circuit. With two wires, connect it to both sides of a bulb
(polarity doesn't matter here). Since all bulbs are wired in
parallel by printed circuitry, all good bulbs will light up;
bad bulbs will remain dark.
