I have a 2018 1500 and It was hit on passenger side.   I purchased aftermarket ANZO lights.    The high beam on passenger side does not work.   So I swapped bulbs and that didn't work.  I took the working driver said and connected it to passenger wiring and that did not work.  Soooo I did not see a separate side fuse in the owners manual.    I did not see anything obvious with the truck wiring.     I need help for the next steps.
  • 3 months later...
On 4/8/2020 at 8:05 AM, silveradosid said:
should be fuse 59 in the under hood fuse panel. it is a 3 pin fuse, power goes to the center of the fuse and the outside pis go to each high beam
It was the fuse and thank you very much !!
  • 10 months later...
I have a 2018 Silverado 1500 LT that I bought from an auction, I am shopping for the headlights.
Would you recommend the Anzos?
Hey Ben,
 I own a 2001 Silverado and just put in some LED headlights from Honcs. They are so much brighter than the old Halogen bulbs, just a recommendation. I got them off Amazon for around 60 dollars for all 4 and they offered me free fog lights for giving them a review.
Thank you Sam!
The headlights are a lot more expensive for my truck (2018 Silverado 1500 LT, HID), the dealer wants $3K for the pair, I have been able to find them used on ebay for $1500, but I am considering the after market brands. That's why I'm asking.
Amazon has the Honks for my Silverado for about $500, which is still not cheap, but a lot better than $3K.
Thanks for your help!
If anyone else has purchased cheaper after market headlights, please let me know your experience.
Ben
    • Today I filled up with 4.899 gallons of fuel at a cost of $4.899 a gallon. $24 bucks. 290 miles. 59.2 mpg. After my 4% COSTCO discount just under eight cents a mile.
    • Howdy folks,   Recently I pulled a heated steering wheel and clock spring out of a 2015 Sierra All Terrain (part numbers coming soon - will have to disassemble), and just installed it on my 2016 Sierra WT (as base model as it gets).   On install, I noticed that I’m missing the connector often tucked behind the dash for the heating element.     No problem… or so I thought.   I used an “Add-A-Fuse” at my heated steering wheel fuse location, which has voltage, but no wires. I ran it to the positive of the heated steering wheel (Violet/White), and took black to ground.   Hooked up the battery, turned the truck on - no heated steering wheel. No button backlights. Was pleased to see that my cruise control was working though.   Read a post suggesting reversing polarity, so I gave it a shot. Violet and White to ground, Black to power.    Aha! Heat! But I seemingly can’t turn it off AND still no backlights on any of the buttons.    Checked all fuses, everything is still in good order. I’m stumped.   Does anyone have any insight? If so, please share!
    • I'm about 1800 miles into my last oil change, and yesterday a message appeared saying oil life was at 77%. Not sure why it popped up but I think all of these electronics could be susceptible to solar flares or somesuch. I change my oil right at 3K each time, and that was the first time in 10870 miles that message came up. Strange thing is that it showed on the screen at all since I don't drive with that sort of info displayed on the DIC.
    • I’m praying that someone sees this and can help me out… pulled a heated steering wheel and clock spring out of a 2015 Sierra All Terrain, and just installed it on my 2016 Sierra WT (as base model as it gets).   On install, I noticed that I’m missing the connector often tucked behind the dash.     No problem… or so I thought.   I used an “Add-A-Fuse” at my heated steering wheel fuse location, which has voltage, but no wires. I ran it to the positive of the heated steering wheel (Violet/White), and took black to ground.   Hooked up the battery, turned the truck on - no heated steering wheel. No button backlights. Was pleased to see that my cruise control was working though.   Read a post suggesting reversing polarity, so I gave it a shot. Violet and White to ground, Black to power.    Aha! Heat! But can’t turn it off AND still no backlights.   Checked all fuses, everything is still in good order. I’m stumped.   Does anyone have any insight? If so, please share!
    • Checked the pads today and there's plenty of meat on them. If the message keeps coming up, I'll just answer YES that the pads were replaced and wait for the squeal.
