Electrical Issue
Having a intermittent electrical issue on my 2016 Silverado 40K miles , (Reg Cab WT 4.3). Severity of the issue varies from annoyance to dangerous.
Here's the difference levels, I believe they're all related, the issue goes away in a split second, but can come back the next time the brake is pressed. In level of severity they are
  1. Can see the small info panel display flickering
  2. When stepping on the brake, radio display goes blank, but radio stays on.
  3. When stepping on the brake, the dash lights and the radio go completely out
  4. When stepping on the brake, same as above but the traction control light comes on
  5. Wen stepping on the brake, the same as above but the air bag light also comes on.
  6. When stepping on the brake, the same as above, but the power steering goes out
No pattern to when these will show up and likewise the severity. Truck will be fine for a couple days, then act up all day long the following day, then go away again.
All these only happen for a split second, but when your're going around a turn and loose PS, its a bit concerning.
I believe there is some sort of electrical spike, triggered by the brake light that is causing these faults. Haven't been able to find root cause.
Dealer said there is no recall on this, but it seems similar to issues on earlier models.
Any thoughts?
This sounds like a grounding issue.  Check the connections on your battery to make sure they are tight and the battery ground on the passenger side on the frame.  I checked mine while doing oil/fluid changing and found that it just screwed into the frame with the wax still applied under it.  I wasn't have any issues but my guess is that it wasn't a very good ground like that, so I took the bolt out, cleaned up the bolt, ring, and frame, then put some dielectric grease over it all.  Seems to be a common thing on these trucks.
Agree with the grounding problem. Battery cables are easiest to access and check and are very common. Other then that there are a lot of other grounds off of the harnesses that could cause something like this. A wiring diagram can show you where they are.
    B07
    B07
  • Who's Online   2 Members, 0 Anonymous, 834 Guests (See full list)
    • Missing pieces of the Assembly   Detergency vs Solvency   Not the same thing. Detergency is the mechanism that surrounds solid particulates preventing amalgamation. Usually accompanied by a Dispersant whose job it is to keep those encapsulated particles in Suspension. Solvency keeps things that can be dissolved in solution.    Salt is a solid that can be dissolved. Pepper is a solid that cannot be dissolved. A detergent/dispersant is effective on pepper but a solvent is more effective on salt. As long as the solids remain in either state, dissolved or dispersed then they can be be removed with the oil upon change.    How many wranglers does it take to herd cats? Depends on how many cats your herding. How much sponge does it take to soak up water? How much water is there to soak up? Point is most oil blends start with some herding ability and next to zero sponge and recently even fewer wranglers are being sent to do the same job.    So you start with a dozen cowboys and zero cows but at the drive progresses you pick up cows along the way, but not cowboys. At some point you have more cows that the wranglers can handle and some leave the herd. Deposits. And the API has an acceptable number of cows they are willing to let loose. In the ideal world zero is the right number for he rancher but to the butcher....a few lost is fine. This cow is beat to death. Let's move on....   Solvency isn't something oils on the Walmart shelf care about AT ALL. Problem is, you motor does. Fuels driven varnish sticks rings and only a solvent can keep them in check. The bet is that the solids driven portion that plug the expander rings and the oil drain backs and VVT screens and AFM screens will be an issue long before varnish is. Not that it wont be but if they market well enough the consumer can be kept ignorant enough to either believe it is "normal" (A quart in 1 or 2K is normal) OR is kept at bay longer than the first owner is likely to hang on to the unit. Solvency cost money.    Now the OEM's have John Q. Public buffaloed into the belief that the number cows accumulated along the trail is a known and predictable CONSTANT. It isn't. Nor is the rate at which they crossed paths with them. Only the number of wrangles is constant. Or was. Each new generation of oil sees fewer and fewer of them.    So what happens when the number of cowboys is lower (lower TBN) with each seasons trail but the trial is longer (OCI) and the number of cows along that trail continues increase? (Conditions that promote deposits).    For awhile the blenders were on to something. Better bases are harder to degrade (fewer cows) but that was overtaken by a longer trail (OCI) and improved breeding (More cows) while continuing to reduce the cowboy staffing levels (TBN/Aniline #).    Marketing has been successful. We've fired most of the staff, cows breed line bunnies, the trail is ten times longer and we've convinced the boss his ranch is in better shape that it ever was.    That kids is just the cleaning side. The side few pay attention to.
    • Looking for this part for my truck. They don't sell just that one piece and to get it you have to pay over $100 even used for the whole air tube. The piece the hose clamp snaps into that is held on by the screw and nut. If anyone has access to one please let me know.
