Obd2 port inoperable
I have a 2006 silverado 1500 4.8. I can not figure out why my scanner won't talk to my dlc port. I have power. I've checked the fuses. Replaced all that were blown. I removed the radio fuse, I removed the info fuse. There is 0.5v at the serial data wire. I even took a multimeter directly to pin 58 on the pcm, still showing 0.5v. I swapped pcm and it still showed 0.5v at the serial data wire.
The site had one like this not to long ago,wound up being the driver's door module,if I remember correctly,there was a issue with the switch,helped the owner narrow down the problem
Check your cigarette lighter fuse. That one is where the OBD port gets its power.
The cig lighters work. There is 12v at pin 16 of the obd2 port. The serial wire is the culprit. It's supposed to have 5 to 7v and it only has 0.5v. Even after swapping pcm, the same thing.
    Brendan C
    Brendan C
  • Who's Online   3 Members, 1 Anonymous, 1,035 Guests (See full list)
