Hello I have a 2013 Silverado Z-71 5.3 that I just had a 2" leveling kit installed and I installed 32" tires. Im sure it has nothing to do with it but afterwards my truck kicked into limp mode with "traction control" "traction stabilzer" "engine reduced power" lights come on. the oil pressure gauge reads 0 PSI as well 'I replaced te oil pressure sending unit as well as a new screen and it still reads 0 oil pressure and still in limp mode. truck has 113,000 miles and does not make any noise or use any oil. I also replaced the IAT, map,sensors as well, im at a loss as the truck was running fine until my detail guy tried to drive in his shop and and all this happened.
Pull the codes. Reduced engine power will give you the fault to look into.
The intake air temp sensor is built into the MAF, so you replace the MAF sensor too?
no i did not replace the MAF, codes are P0107 & P0113
Edited by Westattoo
  • 1 year later...
    Sdid
    Sdid
  • Who's Online   5 Members, 0 Anonymous, 1,399 Guests (See full list)
