SIERRA CREW CAB VENT SHADE
So what is the consensus on vent shades?   Looking to get some for my 2015 sierra crew cab all terrain.  AVS or Weather Tech in Channel or mount on outside? What does everyone have?
Do those create wind noise at all?  I don't think I've ever been in a vehicle that had them.
They make some wind noise but it’s minimal.
I have the “low profile” ones that are not in-channel. I like them. They sit way flatter than the normal tape-ons, you can barely see em.
I keep reading about problems with the rear doors on AVS and Weather Tech in channel has anyone experienced them?
I have had AVS in-channel before. While they look nice, what kept happening to me was that after a while the tape they use on the outer face up in the channel would let go as it’s not the same as the tape on automotive stuff. Plus it’s stuck to the fuzzy window channel, not clean metal or plastic. So after a few months, whenever I’d open my driver’s window, the vent shade would drop down slightly. Not enuff to see that it had, but juuuust enuff to put it out of line with the channel and so as I put my
Window back up, it would snap loudly into place. And eventually it snapped and flew off on the highway.
Went straight back to tape ons after that and never had a problem. And these low-profile ones look about as good as the in-channels, IMO.
AVS in channel....no problems on a 2014!
    DaleB
    DaleB
  • Who's Online   1 Member, 0 Anonymous, 1,335 Guests (See full list)
    • Common Sense Assembly   Your driveline is forgiving of the occasional mistake. It will even often forgive the random serious blunder. But it will not forgive a continuous bad habit.      What? Not everything needs to be a five thousand word essay.
    • We drove about 15 minute east today to visit a friend and saw a steep increase in price in the same county. About 50 cents a gallon steepper.
    • Sure about that? A degree wheel and a dial indicator would lower your degree of assurance in that statement. 😉    It why we have offset keys and dialable timing sprockets. Just say'n.... I've built a few and have never seen one "On the money".
    • I will admit I haven't experimented much with pressure drops beyond the numbers I put in and part of that is that the numbers I used are fairly low and then found out it would trigger regardless at that 35 psi. Having said that I had tried before had changed the placard pressures and being that I have a 1 ton set to 80 on the placard for the rear I believe it triggered close to 60, the front I don't recall now for sure but thought maybe it could get close to 45 from that factory 60 placard pressure. So I never did figure out if it was a number of psi from placard pressure to the alarm or a percentage of the total placard number as some figured it was like a 25% drop from placard pressure would trigger it. So as to try and answer your question, I believe I set the placard pressure on the front to 47 or so and while I run the front tires at 40, they have dipped below that some if its colder and I haven't put "winter air" in yet and never once have had the front alarm go off. I would say that the answer your looking for is no, that if you set your placard pressure to 45, you have a certain amount of room to drop below that pressure before the alarm will go off.    The pressures you decide to run in your truck, that ends up being what makes sense to you based on what your carrying in your truck or if towing, then have to bump them back up to something that will carry the load in the rear and the fronts typically left at the same pressure. It all comes down to that chart I put the link to and using an accurate roadside scale to be your guide, both unloaded and then loaded to know your minimum safe pressures.    I just wish GM would allow a person to change the readings for the tire pressures to the English system of pounds as I have to look at that goofy metric reading that will never ever jive in my head and will go over and change it just to figure out what they are if need be and then change it back.
    • That part I understand, that the dealer can do it. But I'm not understanding why updates that were available to the truck since it left the factory, or the dealership originally, would not still be available to it without dealer intervention.   I'm thinking along the lines of recalls. They stay available until they are completed, regardless of whether they are in warranty or not, or in the hands of the original owner or not. Why not updates as well, especially since some of those can be safety related also?
