Removal and 3M Wrapping the Bowtie on a Z71
Guys just removed the Chevy Bowtie on my '16 Z71 and wrapped it with 3M Vinyl.  I know there are a ton of videos out there already but that it might be useful to have these both for anyone that has a Z71 and wants to do this.  I originally thought that I was gonna have to pull or at least loosed the front grill and that turned out to not be the case.
Chevy Bowtie Removed in 20 seconds!! 2016 Z71
3M Carbon Fiber Wrapped Chevy Bowtie
Definitely agree that it can be done while on the truck, in fact that's how ill probably do the back so that I don't have to remove the double sided tape.
    ballencd
    ballencd
  • Who's Online   5 Members, 0 Anonymous, 713 Guests (See full list)
    • I’m doing an experiment on a vehicle I don’t have much money in. I’m going by the premise that after they last 100K miles they were no mechanical problems with assembly. Or defects with the parts. With oil changes by the minder for the first 127K miles when I acquired it. I quickly went through low mileage oil changes then settled on 5k oil changes with close to 170K miles on the vehicle currently. I did have the option to turn off the cylinder deactivation. I didn’t on this vehicle because in ECONOMY mode at least half the time. It should be a no brainer frequent oil changes are the key. The manufacturer gets away with the long oil changes with its severe service  maintenance. Just ask them what is normal.
    • $5.19 for regular...
