2019 Sierra 1500 SLE
My 17 Silverado had two plug-ins in the center console. I bought the exact same 20 truck and no outlets. Its aggravating. if you want to plug your phone in, now you have to have a cord hanging from the dash. I don’t get it.
About money.
Save $2 per truck times how many trucks.
Or buy a more optioned truck to get them would be my guess.
    thefultonhow
    thefultonhow
  • Who's Online   6 Members, 0 Anonymous, 682 Guests (See full list)
