Aftermarket wheels rub on mud flap/guard
So I know its been discussed on here previously. I cant seem to find the topic when I search. I just put 33X12.5 on 20x9 +1 wheel. It only rubs at full lock on the inside of the front mud flaps. I remember someone mentioning they removed the insider metal bracket on the flaps to gain 1/4 inch to clear. I took it off yesterday and I saw a fairly large bracket attached to the fender then its attached to the flap. Can someone elaborate further or have photos or instructions? Thanks!!
I removed the bracket yesterday and no longer rub. I'm on a 2 inch level with Duratracs in the stock tire size 275/60/20 on a 20x9 +1 and rubbed pretty bad on the passenger side.  There's 4 bright silver bolts to remove the bracket. 2 down low stacked on top of each other. One up higher and 1 around towards the midline of the truck. I think it was a 1/2 inch bolt?
Is there anything structural about this bracket? Looking to run 33s on my leveled RST and am trying to plan ahead for any modifications it'll be needing as well.
Don't think so. Really, the bracket was just a place for the mud guard bolts to screw into. I bought my truck with the splash guards installed from the dealer. These flare out a bit at the bottom while the mud guards follow the wheel well straight down. I believe the new trucks have mud guards from the factory and the splash guards are an accessory add on.
The OEM splash guards that I have, have 2 holes on the inside of the mudguard. One is for a torx bolt, which has nothing behind it to screw into since the bracket was removed, and the furthest hole is for a rivet that is attached to the liner. I removed both to run a zip tie through the 2 holes and attached the zip tie to one of the bolt holes left from removing the mud guard bracket. This tightens up the liner and pulls it back quite a bit opening up a ton of room for the wheels. I then just used a heat gun and formed a nice groove with splash gaurd following the fender liner.
Hope this helps. When you take everything apart and remove the bracket, it will all make sense.
Wow that will be a big help. Great post, thanks for the info!
    • Can it still be Assembled II?   Viscosity on the decline by various means. Heat on the rise making that worse. Engine RPM in the tank. Smaller motors with more boost trying to emulate an electric motor. Full torque, zero rpm. Then we will triple the OCI. Argh.    But wait....there is more. LSPI has pushed a shift from Ca to Mg and as that cost more PLUS the run to lower sulfur compounds the TBN is moving in the wrong direction for the increased OCI's demanded.    That not being enough to placate a demand for a parameter they can't measure the other sulfur bearing compounds are also under attack. That would be zinc and phosphorus sulfonate compounds. To some degree those are being replaced with boron esters and others, i.e. titanium ect. All of which have shorter service lives. And there there is the "Secrete Sauce" marketing for AW adds that 'Can't be detected by UOA's" but trust me because I (the blenders) never ever lie.    Spoiler alert; ALL additives are sacrificial! Smaller amounts of the old blended with less robust versions of the new do not equal longer service lives. So what are the blenders recommending? Wait for it.......   MOVING THE GOAL POSTS! OMG      Let's declare the long standing TAN/TBN crossover irrelevant and tell people that soot is a great 'graphite' based lubricant which can aid tribo films. Wait, what? Let's declare that the standards used for oxidation and nitration were to conservative and can be expanded. Let's tell them that because GDI fuel dilution, although being a VISCOSITY KILLER and an acid generator is actually okay because we have better base oils that limit viscosity failure limits. (Said knowing this is measured in fractions of a centipoise and in bases not commonly used in shelf oils)   Lying from the heart is not just the new normal but we have a public, a very young public, that is so ignorant of the facts and so sure of their "RESEARCH" into AI driven models base in regurgitated  instead of scientific research based unvarnished, peer reviewed FACTS that the incoming guard is loosing their grip on reality and the OEM's are tickled pink while the blends bend the knee.    You have an ever limited set of tools to work with. And sooner or later those will be taken from you as the API and the EPA strangle the last remaining fluids from the system. What you have left is your wits. If you care to use them.    At some point in the very near future it will not longer be possible to do "What is best for the machine", and be replaced with "The best you have access too". You WILL be rewarded with half the life and twice the cost. That isn't that hard to predict.
