Squeaky jump seat console lid
Does anybody know the part number for the console lid for the flip up jump seat?  Mine makes all kind of noises when you rest your arm on it or lean on it.  I would like to purchase a new lid and try that.  It is for a Gmc SLE black interior non-leather.
Itll come right back in a year or so if you replace it. There is a fix for this floating around here somewhere. If I can find it ill post it here.
Sent from my SM-N975U using Tapatalk
    contrabombarde
    contrabombarde
  • Who's Online   1 Member, 0 Anonymous, 897 Guests (See full list)
    • I'm sure if you went to a junkyard where you go in and pull the part off the truck yourself, not a used part place where they do it for you, you can get that part on it's own.  Depending on if and what else you would be buying, and time of day, they might even just skip over adding it as a item to the bill.
